07-18-2012, 08:45 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | How To Upgrade Iphone 3gs 4.1 bb 6.15 To 5.1.1 |
07-18-2012, 08:48 | #2 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | http://forum.gsmhosting.com/vbb/f456...1-1-a-1500802/ No problems you will find if you used search too Regards |
The Following User Says Thank You to ~Leo~ For This Useful Post: |
07-18-2012, 08:50 | #3 (permalink) |
Insane Poster Join Date: Dec 2008 Location: USA
Member: 927532 Status: Offline Thanks Meter: 7 | I updated to 5.1.1 today and upon jailbreak downgraded to old baseband then ultrasn0w worked perfect. Use latest Redsn0w |
The Following User Says Thank You to Moody69 For This Useful Post: |
07-18-2012, 09:37 | #4 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | * What ipsw I have to use to upgrade to 5.1.1? Normal or Custom? * If Custom, where to get it? * What will be the baseband after update. I have 6.15 baseband already. |
07-19-2012, 08:01 | #5 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Can I update 3gs new bootrom to 5.1.1 without any problem? Will it be tethered or untethered? Can I downgrade its baseband from 6.15 with redsn0w_win_0.9.14b1 |
07-19-2012, 11:54 | #9 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | I am getting error 1601. I uninstall all apple installations but same problem occurred then I reinstall windows and now I am getting error 1600. Any solution to get rid of this problem? |
07-19-2012, 12:07 | #10 (permalink) |
Freak Poster Join Date: Sep 2008 Location: U.S.A
Member: 856640 Status: Offline Sonork: 100.1606320 Thanks Meter: 281 | Use REDSNOW9.14b2 for jailbreak and installing baseband... iPhone3GS 5.1.1 Update&Downgrade BB JB/Unlock[COMPLETE GUIDE] for error 3194/1600/1601 first close itunes goto my computer/drive C:/windows/system32/drivers/etc/host cut hostfile and save it to your desktop..then open itunes and restore your device... good luck |
07-19-2012, 12:22 | #11 (permalink) | |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Quote:
07-20-2012, 20:23 | #12 (permalink) |
Junior Member Join Date: Nov 2008
Member: 906916 Status: Offline Thanks Meter: 3 | 3gs 4.1 to 5.1.1 with 6.15 baseband To upgrade iphone 3gs version to 5.1.1 I have use this procedure: 01. Use redsnow 0.9.12b1 open and go to Extras 02. Now type Custom IPSW ( Preserve baseband with a custom firmware ) 03. You will select Restore IPSW 5.1.1 for 3gs 04. After redsnow do the job you will flash the Iphone with this Custom Firmware it is very important to enter in DFU mode with this redsnow . 05. After that you will Jailbreak your Iphone with this redsnow same as firmware 4.1 So you must select Install Ipad baseband again . 06. After Jailbreak you you can use DiskAid to put 3 files of Ultrasnow fixer 5.1.1 So now you can enyoj your Iphone 3gs with 5.1.1 firmware and 06.15 bb |
Easy way to check shorting in nokia phones | digitized | Nokia Hardware & Hardware Repair | 445 | 11-29-2023 21:29 |
Nokia SL3 Unlock promotion for HTI -125 HTI credits | MANOLE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 86 | 09-15-2012 08:27 |
BB5 Flashing & Infineon unlock bug fixed [latest filepack V8.14] 29-05-2012 | Ja\/\/aD | Universalbox | 68 | 07-29-2012 18:57 |
Help updating firmware ATF - [SOLVED] | caid2006 | Advance-Box | 11 | 07-17-2012 10:48 |
