09-20-2012, 06:55 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 815280 Status: Offline Thanks Meter: 11 | Howto downgrade iphone 4 ios 6.0 to ios 5.1.1 real nice "outfit" when trying ios 6.0 then,but luckly i wont be able do anything since its lock,and the BB upgrade to 04.12.02 when at ios 5.1.1 its 04.12.01..so i try to downgrade to ios 5.1.1 back,but it gives me error (-1). But since apple still sign ios 5.1.1,so i try this method.. 1. Do clean uninstall itunes 10.7.0.21,including registry in windows 2. Install itunnes 10.6.3.25 3. restore to stock 5.1.1 4. wait...and walaaaaa...its back to BB 04.12.01 So then i restore my unlock ticket,and things just fine... |
The Following 5 Users Say Thank You to nebula_andra For This Useful Post: |
09-21-2012, 21:04 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: esmeraldas-ecuador
Member: 392589 Status: Offline Sonork: 1597152 Thanks Meter: 50 | Quote:
09-21-2012, 21:14 | #3 (permalink) |
No Life Poster Join Date: Jun 2007 Location: E G Y P T Age: 37
Member: 527884 Status: Offline Sonork: 100.1583794 Thanks Meter: 850 | Now Apple Stop Signing 5.1.1 So Only Way To Downgrade By SHSH Regards B,R |
The Following User Says Thank You to shedeed For This Useful Post: |
09-21-2012, 23:03 | #4 (permalink) |
Insane Poster Join Date: May 2012
Member: 1762185 Status: Offline Thanks Meter: 53 | Downgrade Apple closing holes Blob-o-riffic |
The Following 2 Users Say Thank You to timex567 For This Useful Post: |
09-26-2012, 07:07 | #6 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1816252 Status: Offline Thanks Meter: 0 | if your restore went thru to the loading firmware stage and then error -1 showed up all you need to do is go ahead and jailbreak even though it didnt complete the restore. So use DFU to and custom ipsw in itunes restore, it boots you out, do it again as it is in recovery mode, error 1618 its still gonna boot you out put in the process it resets important info, I also ran iReb and manually set auot-boot to true, then I went ahead and jailbroke. I have an iphone 4 gsm that went byebye 4 days ago, been working ever since finally got some where, I ended up having to restore to ios 6 because of recovery loop issues, missing firmware, im sure was do to a cracked app. Anyway been going at it to downgrade back down to ios 5.1.1 build 9B208 ever since. What I did do was create the custom ipsw by stitching my shsh blobs 5.1.1b in redsn0w 0.9.14b2 with the ipsw download build 5.1.1 9B208, put in pwd dfu and went to itunes. Then error 37? just to say dont try and use someone elses shsh files aint gonna work, then thru error 1600 with tiny umbrella, did the host file addon there, then ended up with error 3194 with iReb and while looking for that fix i came across what someone said to just go ahead and jailbreak, cause getting iRec to work is a pain, I know it, so I did. So here I am waiting on my phone to finish loading my "icloud" restore, thankful a few months old so no issues there, no ios 6 running around in that. And just to let you know I thought I was done for cause I couldnt find my shsh blobs, thankfully while my iphone was stuck in recovery loop I opened redsn0w and fetch and saved and sent while I had a connection. I also had to reset Internet explorer internet settings to default, and I did put a # sign in front of the ip of the gs.apple in the host cause it didnt work with out it. If anyone needs help I went thru a few thousand ways and will offer any ideas or help i can. just glad to have my 5.1.1 back! and Cydia of course! |
09-27-2012, 15:08 | #8 (permalink) |
Junior Member Join Date: Jan 2009
Member: 955475 Status: Offline Thanks Meter: 5 | Downgrade from 6.0 to 5.1.1 Make custom firmware by stitching your shsh blob. with redsnow 0.9.14b2 edit host file Pwned DFU run TSS server in tiny umbrella Restore with Custom firmware at last you will face 11 error and recovery mode Put your device DFU & Jailbreak At last you are at 5.1.1 |
09-28-2012, 09:23 | #13 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: BANGLADESH
Member: 1813575 Status: Offline Thanks Meter: 90 | Quote:
Iphone 4 successfully downgrade factory unlocked phones Important Need SHSH blob for ur phone 1-Open redsnow 0.9.14b2 2-Choose extras 3-choose shsh blobs 4-Choose stitch 5-Select ipsw 5.1.1 6-Choose local and Select ur blob which u saved in tiny umberlla 7-Now ur custom firmware will be created in same folder 8-Then put ur phone in dfu 9-Pwned ur dfu mode 10-Then open tiny umberlla and click start tss server 11-Open itunes and restore ur custom firmware 12-During restor itunes says -1 error dont panic in this stage 13-Just run redsnow 0.9.14b2 and jailbreak ur phone with deactivate option 14-U do not choose deactivate option in in redsnow means phone says no service Enjoy with untether jailbrek | |
The Following 4 Users Say Thank You to ..:ALAK:.. For This Useful Post: |
09-28-2012, 17:26 | #14 (permalink) |
Member: 1817105 Status: Offline Thanks Meter: 1 | Downgrade without any error Best method,... use Ifaith to create signed ipsw(ios 5.0.1) using your SHSH Blobs.. then use this firmware to restore your phone... phone will be downgraded with any error... |
The Following User Says Thank You to deepugagan89 For This Useful Post: |
