09-04-2012, 09:52 | #1 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | I need All Seniear Member help Request only How to solve “Unable to recognize specified IPSW” Error in Redsn0w When user tries to browse iOS 4 firmware file from Redsn0w, an error pops up “Unable to recognize specified IPSW”. This problem can be solved by the following methods. 1) Make sure that you have installed right build of Redsn0w. In this case it should be Redsn0w 0.9.5b5-5. You can Download Redsn0w 0.9.5b5-5 from Here. 2) Make sure that the right build of iOS4 firmware file is being used for iphone 3G. There could be confusion because Goldmaster (GM build) and Final release uses the same build number so filename both would be the same, that means iPhone1,2_4.0_8A293_Restore.ipsw but Redsn0w 0.9.5b5-4 would only be able to verify the Final release of iOS4 firmware so make sure to download it from trusted source. You can download verified iOS4 firmware file from Here. List of links for all devices : iPod Touch 2G iPod Touch 3G iPhone 3G iPhone 3GS iPhone 4 source : 2lix.com |
09-04-2012, 12:56 | #3 (permalink) |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | whats the software running on iphone u want to jailbeak/service? Understand that its the software version running on the 'idevice' that will determine the redsn0w you will need. Today's latest version of redsn0w actually supports latest ios firmware 5.1.1 backing up support till 4.0 on all devices . Anything earlier your going to need previous versions. in all cases google is your friend! goodluck ndagi |
driver problem please help[ANSWERED] | birdonsky | HUA GOLD Old | 6 | 09-04-2012 18:50 |
help medusa box | KIKO_GSM | Medusa | 15 | 09-04-2012 11:25 |
plz help c right c55 spd flash file thanx | kifayatjan | Dragon Flash Files | 0 | 09-03-2012 10:14 |
i9100t 4.0.3 unlock help [Solved] | ong3822 | Activation Software Support (HTC, BLACKBERRY, ALCATEL, LG/ZTE, SAGEM/SE) | 6 | 09-02-2012 13:15 |
