11-13-2009, 05:02 | #1 (permalink) |
Junior Member Join Date: Jan 2007 Location: Los Angeles
Member: 426096 Status: Offline Thanks Meter: 5 | Iphone 2g 3.1.2 dead killed no power bricked ? |
11-13-2009, 05:57 | #4 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Turn ur iphone in DFU Mood by pressing power+Home boton 10 sec. and relies power but still home botton press. Then Restore it It will be solved. |
11-13-2009, 07:05 | #7 (permalink) |
No Life Poster Join Date: Dec 2006 Location: philippines
Member: 418718 Status: Offline Sonork: 100.1589777 Thanks Meter: 360 | disassemble ur iphone then try to charge ur battery from power supply and set ur power supply to 3.7v then put positive and negative to batt.coz i think that u try to restore from ur iphone to 20% low batt.. |
11-13-2009, 07:13 | #8 (permalink) | |
Member: 426096 Status: Offline Thanks Meter: 5 | Quote:
Thanx | |
11-15-2009, 23:17 | #9 (permalink) |
Member: 426096 Status: Offline Thanks Meter: 5 | I opened the iPhone and tried to jump / charge the battery no luck ...... I had to replace the Mainboard with another. What are the proper steps to unlock a 2G iPhone with 3.1.2 FW Thanx |
11-16-2009, 05:07 | #10 (permalink) | |
Freak Poster Join Date: Apr 2007
Member: 496243 Status: Offline Thanks Meter: 42 | Quote:
BTW, you can not jump charge the battery when it's connected to the board, you'll have to disconnect it from the board and check the voltage or charge it. Regards | |
The Following User Says Thank You to dcg28052 For This Useful Post: |
11-16-2009, 08:02 | #11 (permalink) | |
I had already tried all that you mentioned with no luck. When I put the replacement board in the iPhone the iPhone powered up fine. So that tells me the battery is not bad. If i had a bad battery the iPhone wouldn't have powered up when i replaced the mainboard ... I tried to power up the BAD board in a different iPhone and came up with the same result > Dead iPhone > No Power. : ( | |
02-18-2010, 14:11 | #13 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Bulgaria Age: 36
Member: 37668 Status: Offline Thanks Meter: 15 | The solution: Unplug Iphone from USB Hold home button Connect usb while holding the button Itunes will find it ( display still black ! ) Hold Shift and cli restore Choose correct FW Wait for update Exit Itunes Connect USB Run Blackrain I had the same problem and this is the way for me. Good luck |
02-27-2010, 01:49 | #14 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1246595 Status: Offline Thanks Meter: 0 | I have the same problem, I just got the phone one month ago (3gs 32gb 3.1.2) and now its bricked, cannot access DFU mode, no power, neither holding power and home button, nothing, it is dead... I was thinking to take it over the company where i purchased the phone to get another one, but will they found out that is jb? or they will restore the phone and never know that the phone was jb?. But before i do that i was woundering if there is a way to access DFU mode in this situation. Thanks in advance |
03-02-2010, 07:43 | #15 (permalink) |
Member: 1246595 Status: Offline Thanks Meter: 0 | Hi there, i just saved my iphone , but i couldn't figure out how i did it. I didnt use my iphone for the past days, and i just pluged the phone to the pc without power and then turn the pc on and boom! there was the battery charging icon on the iphone!.. i just wait till it have some charge then i just power on the phone and access recovery mode and from there just did blackra1n (note: at the first time i did blackra1n and it powered of, but i tried it twice and it worked). This situation was so weird because my iphone was dead no dfu mode no usb detection no nothing, tried irecovery, blabla and nothing, and from nowhere started working. I dont know if the solution was to drained the battery or plug the phone to the pc and then just power on. So if someone has the same problem i suggest to wait...and dont know maybe you could get lucky, maybe the iphone is just lazy... |
iphone 2g 3.1.2 jailbrake ok but no nework.plz hep me. | ck.sufail | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 03-23-2010 14:35 |
is possible to downgrade iphone 2g 3.1.2 to 3.0??? | svchost | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 12-11-2009 10:38 |
possible to jailbreak and unlock iphone 2g 3.1.2 ? | greenwise | iPhone 2 / iPhone 3G / iPhone 3GS | 13 | 12-04-2009 17:54 |
How to unlock iphone 2g 3.1.2 firmware | M Sudheer | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 10-30-2009 19:39 |
iphone 2g 3.1.2 jailbreak | scorpion_bashee | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 10-16-2009 20:27 |
