01-14-2010, 04:50 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: mexico
Member: 194712 Status: Offline Sonork: 100.1580741 Thanks Meter: 212 | blackrain stuck in entering recovery iphone dont goes to recovery mode or dfu mode please advise b.r aleon |
01-14-2010, 05:06 | #3 (permalink) |
Member: 194712 Status: Offline Sonork: 100.1580741 Thanks Meter: 212 | the original problem iphone stuck on iphone is disabled connect to itunes but when i connect to itunes cant activate it because have phone code so i try to put in dfu mode but home button dont work what can i do? also i try with usb cable by "c:/dfu/dfu iBSS.m68ap.RELEASE.dfu" please help b.r aleon |
01-14-2010, 05:30 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2009 Location: Spain Europe
Member: 1102864 Status: Offline Sonork: 100.1681662 Thanks Meter: 854 | Hello aleon which version are you using in your iphone is the way which software will be compatible to boot your iphone in recovery mode and could be restored from Itunes... |
01-14-2010, 05:32 | #7 (permalink) |
Member: 1102864 Status: Offline Sonork: 100.1681662 Thanks Meter: 854 | Could you please describe me when you buyed your iphone? And when did you updated your iphone... I could guess from it which version you are using.. If it's older 3.0 it's too easy for you... |
01-14-2010, 05:42 | #9 (permalink) |
Member: 1102864 Status: Offline Sonork: 100.1681662 Thanks Meter: 854 | If your iphone is older than you could download ZiPhoneWin-3.0.exe and if it supports it will go toomuch easy for you to make your iphone put in recovery mode or any other mode.... |
01-14-2010, 05:50 | #10 (permalink) |
Member: 1102864 Status: Offline Sonork: 100.1681662 Thanks Meter: 854 | Oh ! sorry it may not work coz you already in a firmware version of 3.1.2. You were hanged by Blackra1n. you could again try blackra1n to perform it's tasks... If it worked than you will feel easy.. |
The Following User Says Thank You to cfrommyside For This Useful Post: |
01-14-2010, 05:59 | #12 (permalink) |
Member: 1102864 Status: Offline Sonork: 100.1681662 Thanks Meter: 854 | press your iphone power button and shut it down and try to press home and power button if it worked it's good . |
Iphone Stuck In Recovery Mode | Emmanuel 01 | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 09-09-2008 16:20 |
I-phone stuck in recovery mode | mcandre | iPhone 2 / iPhone 3G / iPhone 3GS | 27 | 08-13-2008 08:25 |
2.0 2g iphone stuck in recovery mode | ibrahimmoosa | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 08-06-2008 12:35 |
iphone stuck in recovery mode | gopalg73 | iPhone 2 / iPhone 3G / iPhone 3GS | 6 | 01-09-2008 22:24 |
