12-25-2008, 20:28 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | iPhone 2g problem with camera, always show pink colors |
The Following User Says Thank You to Boshko_Alfa For This Useful Post: |
12-25-2008, 21:04 | #2 (permalink) |
Junior Member Join Date: Apr 2008
Member: 762110 Status: Offline Thanks Meter: 0 | test this connect you iPhone with you iTune and wait it for synce finish and turn off you phone and open you phone while USB connecting if work you camera will mormal if not work ithink you should restore you iphone |
02-09-2010, 07:35 | #8 (permalink) |
Crazy Poster Join Date: Jul 2007
Member: 550713 Status: Offline Thanks Meter: 3 | try checking out the 3 same looking IC right behind the camera socket. if they are all working, all of them should connect to the other parallel side without battery. If not then find a new one to replace it. |
02-09-2010, 23:42 | #9 (permalink) |
Member: 550713 Status: Offline Thanks Meter: 3 | XD I am not good at explaining stuff. I got it by testing with 2 board with the same problem with a good board. I haven't try out the solution since I haven't get my heat gun yet. But I am looking forward to changing those little guys as my first heat gun project. I have at least 80% confidence that those IC are the problem. If you think its a hardware problem then you can try testing them with a multimeter. http://img713.imageshack.us/img713/4217/2gcamera.jpg without battery both side should be connected like the red lines, if one of them is disconnected it can give you a distorted camera. if they are broken you should find a replacement from another iphone and replace it. Hope this can help some people that is still playing around with iphone 2g. Last edited by Mogkupoppo; 02-09-2010 at 23:47. |
06-13-2012, 08:36 | #15 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1143429 Status: Offline Thanks Meter: 3 | brother try this link http://*****i.com/forums/hardware/79...blem-done.html Last edited by karunakaran; 06-13-2012 at 08:43. |
Iphone 2G problem with power button in standby.... | Burnt Cobba | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-28-2009 14:11 |
iphone 2g problem with wifi no wifi | uburo22 | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-16-2009 22:03 |
iphone 2g problem with 3.0 fw | ervini | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 10-05-2009 10:43 |
WAWA Cartoon phone With Camera & Bluetooth - Pink | IPMART | ipmart WebShop | 0 | 07-08-2009 15:00 |
iphone 2g restarts on camera ??? | harish35200 | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 12-23-2008 10:41 |
