Old 02-20-2012, 21:45   #1 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
iphone 3g 4.2.1 wifi problem
my problem is that when i jailbreak it using redsn0w_win_0.9.6b5 the phone works normally but when i come to unlock it using cydia i can't connect to internet because wifi can't find any wireless modem and it stays at finding networks when i power it off and on again it finds modem then suddenly the connection drops quickly the base band was 05 15 04 but now is in ipad base band to unlock it 06,15
any solution ?
Old 02-20-2012, 22:03   #2 (permalink)
irshu41187's Avatar
Member: 982178
Thanks Meter: 48
any solution ?
Unlock it manually using iphonebrowser or ifunbox to copy the ultrasn0w and mobilsubtrate files in cydia and create a folder name autoinstall and copy the two files in there and reboot your phone two times and it should be ok
Old 02-21-2012, 02:48   #3 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Use iFunbox or phone browser and upload latest 1.2.5 ultrasn0w with mobilesubstrate
Old 02-21-2012, 08:40   #4 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
the problem is that i am speaking about the wifi how to fix it
Old 02-21-2012, 08:47   #5 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
i solved this problem .
you need to use snowbr and crate sn0wbreeze_iPhone_3G-4.2.1
use itunes to update firmware (sn0wbreeze_iPhone_3G-4.2.1).
if not succed you need to open your iphone and rehat wifi ic.
( lathenache)
lahdache
The Following User Says Thank You to lahdache For This Useful Post:
Old 02-21-2012, 10:14   #6 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
yes i did this but i face at last step in i tunes error 1015 (at the end of the progress bar of iphone)
Old 02-21-2012, 12:15   #7 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
confirmed hardware problem in wifi module
Old 02-21-2012, 12:23   #8 (permalink)
Member: 110191
Sonork: 100.1591395
Thanks Meter: 5
yes its confirmed hardware problem rehat the wifi module carefully your problem will solved try and post result
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.15881 seconds with 9 queries
