12-07-2010, 00:53 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | 3gs update without baseband -> easyest way ever! when you load your restore file into itunes, itunes connect to sourik server (if you set hosts file) or to apple server. if blobs are saved or apple is signing your fw you whant to write to phone, then it starts flashing... now you see on your iphone the progressbar. now just disconnect your internet connection because itunes whant to get baseband signature from apple server, it trys to connect to the apple certifacte server, but since you disabled the internet access, itunes whont get the certificate and therefore it cant update your baseband and will quit with error code... THATS GOOD! now kick your iphone out from recovery mode with tinny umbrella or iRep or whantever else you prefer to use... your iphone is now starting with new fimrware and old baseband! ATTENTION: i have tested it with 3G and 3GS 3G is NOT WORKING, it will update the baseband! 3GS is 100% working with my methode! 4G i dont know... dont have tested it. so for 3GS this is the saves prozess to make update without updating your baseband.... DONT USE THIS METHODE WITH NORMAL iPHONE 3G! i think with iphone 4 it should work too.. wbr. hari |
The Following 18 Users Say Thank You to oOXTCOo For This Useful Post: |
12-07-2010, 01:16 | #2 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: GSMinators LAND Age: 40
Member: 661523 Status: Offline Thanks Meter: 205 | Quote:
Will you be able to kick out from recovery mode after that you have flashed 4.2.1? Thanx for great info! br misiu22 | |
12-07-2010, 02:10 | #3 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 565487 Status: Offline Sonork: 100.1590618 Thanks Meter: 35 | Quote:
thanks great info... | |
12-07-2010, 05:54 | #6 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | pictures and steps? yo, he has wrote it very clearly ... DISCONNECT INTERNET after your itune start updating your phone ... that is all |
The Following User Says Thank You to gwaai For This Useful Post: |
12-07-2010, 06:12 | #7 (permalink) | |
Freak Poster Join Date: Mar 2004
Member: 60474 Status: Offline Thanks Meter: 658 | Quote:
http://forum.gsmhosting.com/vbb/f456...guide-1154534/ | |
12-07-2010, 07:38 | #8 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Philippines Age: 36
Member: 758106 Status: Offline Sonork: jap_line Thanks Meter: 412 | very nice trick! my only question is, this is for 4.2.1 right? the problem on 3gs (NB) 4.2.1 now is "thetered" when you jailbreak even you have lower baseband, so it still a problem it's still better to stay away from 4.2.1 (for unlockers) so you can avoid thetered jailbreak problem and stay 4.1 and lower am i right? btw, again very nice trick sir.oxcto i know this can be useful in some way Br. |
The Following User Says Thank You to jap_line For This Useful Post: |
12-07-2010, 08:11 | #11 (permalink) |
Freak Poster Join Date: Oct 2010 Location: emrites
Member: 1427645 Status: Offline Sonork: sohail---- Thanks Meter: 27 | update after no sound helloo any bosy help pls i update ipad ver.4.2 after no sound..and same thing iphone4... pls help me argent,,,thnx |
12-07-2010, 08:39 | #12 (permalink) | |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | Quote:
u will be stuck in a tetherd jalibreak if u will update to 4.2.1..so now a days no need to save baseband all u have to care about is to keep 3gs software version lower than 4.2.1.. Any sugestion for this process will be a great help for all members... even with 5.15 baseband u have to update base band for unlock to 6.15. | |
12-07-2010, 11:37 | #13 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | shure, i update only to 4.1. but with this trick you can save you bb. when i tested other tricks my bb always updatet, but without internet connection on 2nd check it cant update. this idea come to my mind when i reded a post here about bb downgrade and needed certificates wich get downloded later in the update process. |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
12-07-2010, 12:47 | #14 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Very Good Trick Indeed will test myself, on the weekend. on the 3g,3gs and 4g Im sure it wont work on 4.2.1 right, due to the firmware checks? Thank you Best regard |
Need 3210 5.31 software without opening phone, can exchange for: | igor_m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-2000 13:38 |
Nokia 6110 without net. couldnīt call 911 either! | DennisT | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-09-2000 11:37 |
Have seen Nokia 6150's SPUnlocked + IMEI Change without and cables!! | KingOfKingston | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-12-2000 12:45 |
Impossible without TDF-4? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-22-1999 22:32 |
