05-24-2011, 22:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 44
Member: 88333 Status: Offline Thanks Meter: 48 | iphone 3g stuck when restoring.. any idea on how to succed? thanks a lot in advance i tried to flash again the iphone with the same custom firmware but this time it always gives me error 1601 and it doesnt flash the device,perhaps i should use another custom firmware? thanks again |
05-25-2011, 07:55 | #4 (permalink) |
Member: 88333 Status: Offline Thanks Meter: 48 | its not stuck in recovery mode,so no way i can use tiny umbrella. now i always get 1601 error if i try to put the custom firmware while if i try to put the normal firmware then it gets stuck while flashing the phone half way to the end... looks like i cant do this job.... |
05-25-2011, 15:25 | #5 (permalink) |
Major Poster Join Date: Jul 2007 Location: Pakistan , LAhore Age: 39
Member: 538854 Status: Offline Thanks Meter: 3 | hi bro here is your soulution 1 you restore your iphone 3g with 4.1 version when the restoring bar go to half or end and stuck 2 you must remove your cable does not Waite 3 off iphone with power button and home key 4 on iphone when he go to recovery mod you can exit recovery with tiny umbrella or ireb 4.0-4.1 5 when iphone goes to emergency screen you can jail break with redsn0w 9.6b5 only install cydia and check modem firmware or imei number or wifi or blue tooth and still searching with out unlock so you dont worry 6 you must again jailbreak with redsn0w 9.6b5 with install baseband ok your problem will be solved insh***** ok Tell me must ok baye take care |
when? | dogpound | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-01-2002 16:21 |
Downloads restored :) | GSM_guru | GSM Mobile Links | 0 | 11-25-2001 16:24 |
HEX for CLIP to restore Factory Defaults | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2000 15:59 |
When do they come to Norway? | Rydin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-14-1999 10:06 |
