Iphone 3G wifi Problem not searching any wifi...... I have an iphone 3G and it has wifi problem its not searching any wifi network how to resolve this problem |
flash with 3.1 2 rostore file and then use blackra1n install cydia and snow for unlock and then check your wifi poblem "ll be solved b.r OMER |
but how can i install cydia when?":? when my wifi is not functioning..... |
Maybe you need to restore network setting! Try it! |
I believe the solution will be you upgrade to version 3.1.3 firware and the base will be 5.12 and its release will be lost in time out until a solution to this latest version your wi-fi will work perfectly. |
Hi, here is what you need to do: 1. go to setteings and make "Network settings reset" - check wifi 2. Make restore with 3.1.2 firmware. - check wifi. if after that the wifi is not working its probably Hardware problem. so take apart your iphone and rehot the wifi IC. send results. Afrimian |
Updating your iphone through itunes is a good first step. I have opted out of using the wifi settings because of my area coverage. I enabled my 3G network instead of using wifi. You can find these options under settings-->network. --- Sell Your Songs online |
jus resetting setting go to setting general reset setting reset network setting now your phone is ok for wifi |
