Old 06-01-2010, 00:18   #1 (permalink)
nofear99's Avatar
Member: 1157693
Thanks Meter: 122
Question Iphone 3G wifi Problem not searching any wifi......
I have an iphone 3G and it has wifi problem its not searching any wifi network
how to resolve this problem
Old 06-01-2010, 07:32   #2 (permalink)
oMeR_Rasheed's Avatar
Member: 466635
Sonork: 100.1614186
Thanks Meter: 478
flash with 3.1
2 rostore file and then use blackra1n install cydia and snow for unlock and then check your wifi poblem "ll be solved
b.r
OMER
Old 06-11-2010, 12:34   #3 (permalink)
nofear99's Avatar
Member: 1157693
Thanks Meter: 122
Question but how can i install cydia when?":?
when my wifi is not functioning.....
Old 06-11-2010, 12:56   #4 (permalink)
Syri's Avatar
Member: 246507
Sonork: 1605191/Energy
Thanks Meter: 62
Maybe you need to restore network setting!
Try it!
Old 06-11-2010, 13:19   #5 (permalink)
Member: 1038468
Thanks Meter: 52
I believe the solution will be you upgrade to version 3.1.3 firware and the base will be 5.12 and its release will be lost in time out until a solution to this latest version your wi-fi will work perfectly.
Old 06-11-2010, 13:27   #6 (permalink)
Member: 995791
Thanks Meter: 15
Hi,
here is what you need to do:
1. go to setteings and make "Network settings reset" - check wifi
2. Make restore with 3.1.2 firmware. - check wifi.
if after that the wifi is not working its probably Hardware problem.
so take apart your iphone and rehot the wifi IC.
send results.
Afrimian
Old 06-11-2010, 18:32   #7 (permalink)
Member: 1306497
Updating your iphone through itunes is a good first step. I have opted out of using the wifi settings because of my area coverage. I enabled my 3G network instead of using wifi. You can find these options under settings-->network.
Sell Your Songs online
Old 06-11-2010, 18:56   #8 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 595
jus resetting setting
go to setting general reset setting reset network setting now your phone is ok for wifi
Old 04-08-2011, 16:57   #9 (permalink)
Member: 1504159
Sonork: zohaib111
Thanks Meter: 2
still same problm........
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.53218 seconds with 8 queries
