12-18-2011, 02:34 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Inside World
Member: 1184979 Status: Offline Thanks Meter: 104 | iPhone 3gs 16gb cannot Regonize The Battery Problem iphone 3gs 16gb problem cannot Regonize battery try to change onther battery but same problem Try To jumper Fus Still No Luck Please Need Idea How To Solved Problem |
12-18-2011, 12:24 | #2 (permalink) |
Freak Poster Join Date: Sep 2008 Location: U.S.A
Member: 856640 Status: Offline Sonork: 100.1606320 Thanks Meter: 281 | first disasseble the idevice... prepare for new dock.. usb cable. power supply. PC.. now set the power supply to 4 volts then connect the new charging dock... open itunes connect the supply and the USB cable connected to PC.. if there's a diflection on ameter atleast .8 amphere diflects more than 2amphere and detected by itunes... your circuit board is good... and the problem is charging dock and set of UI(power switch,headset,mute,volume).....also check battery again... if the solution said above does't work... your circuitry board is dead... good luck my friend... |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
