10-09-2011, 19:16 | #1 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1669986 Status: Offline Thanks Meter: 0 | iphone 3gs 4.1 with 06.15 bb stuck |
10-09-2011, 20:45 | #4 (permalink) |
No Life Poster Join Date: May 2010
Member: 1300483 Status: Offline Thanks Meter: 27 | if u people wana write an answer so give a proper answer plz u can do it without a custom firmware as well just follow these istruction working 1000000000000% 1.first locate the host file which u will find in c/window/system 32/drivers/etc/host 2.open the file in note pad and remove very last 2 lines 3.now se ireb or redsnow new version any thing and put your phone in dfu mode 4.now u dont need a ustom firmware just use 4.1 firmwre and restore 5.when u get eror 1015 leave that i tunes open dont do any thing with it 6.now open tiny umbrela select your device and press exit recovery 7.then come back to i tunes which was open if that eror 1015 there quickly pres ok thats all u need to do trust me mate that workd for me |
10-10-2011, 13:36 | #5 (permalink) |
No Life Poster Join Date: Nov 2008 Location: France
Member: 894650 Status: Offline Thanks Meter: 11 | [QUOTE=taz1234;7789353]if u people wana write an answer so give a proper answer plz u can do it without a custom firmware as well just follow these istruction working 1000000000000% 1.first locate the host file which u will find in c/window/system 32/drivers/etc/host 2.open the file in note pad and remove very last 2 lines 3.now se ireb or redsnow new version any thing and put your phone in dfu mode 4.now u dont need a ustom firmware just use 4.1 firmwre and restore 5.when u get eror 1015 leave that i tunes open dont do any thing with it 6.now open tiny umbrela select your device and press exit recovery 7.then come back to i tunes which was open if that eror 1015 there quickly pres ok thats all u need to do I tried as u explained but it's always on recovery mode. pls any other solution pls ? |
10-10-2011, 15:18 | #8 (permalink) |
Crazy Poster Join Date: Jun 2010
Member: 1332600 Status: Offline Thanks Meter: 1 | Ok I Have same phone same basebund First make this steps 1.first locate the host file which u will find in c/window/system 32/drivers/etc/host 2.open the file in note pad and remove very last 2 lines 3.now se ireb or redsnow new version any thing and put your phone in dfu mode 4.now u dont need a ustom firmware just use 4.1 firmwre and restore 5.when u get eror 1015 leave that i tunes open dont do any thing with it then what changed 6. downlaod redsn0w_0.9.8b7c browse 4.1 firmware and select only deactivate 7. after done, you will come to the activate with orginal sim 8. run again redsnow and only select install cydia and you done :-) |
10-10-2011, 15:18 | #9 (permalink) |
Member: 1332600 Status: Offline Thanks Meter: 1 | Ok I Have same phone same basebund First make this steps 1.first locate the host file which u will find in c/window/system 32/drivers/etc/host 2.open the file in note pad and remove very last 2 lines 3.now se ireb or redsnow new version any thing and put your phone in dfu mode 4.now u dont need a ustom firmware just use 4.1 firmwre and restore 5.when u get eror 1015 leave that i tunes open dont do any thing with it then what changed 6. downlaod redsn0w_0.9.8b7c browse 4.1 firmware and select only deactivate 7. after done, you will come to the activate with orginal sim 8. run again redsnow browse again 4.1 fw and only select install cydia and you done :-) Thats the simpel version, run step 8 only if you will jailbrek you phone :-) Last edited by mobitel2002; 10-10-2011 at 15:25. |
10-10-2011, 23:13 | #10 (permalink) |
Member: 1300483 Status: Offline Thanks Meter: 27 | u guys are good at doin copy again my instructions are same u guys dont need a custom firmware when u flash ur phone first time just put ur phone in dfu and flash it with 4.1 then u will get the eror 1015 now without dfu mode flash it with 4.1 again u will get rocovery mode again and eror 1015 this time open tiny umbreala and exit recovery bounce bk to the i tunes and pres ok to the eror 1015 ur done |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
