Old 12-06-2010, 03:25   #1 (permalink)
Member: 951140
Iphone 3gs Baseband 06.15 stuck at recovery mode?
did exactly the same thing as you. I've been searching everywhere for the past 2 hours for a solution to the problem. I read somewhere that you can't kick out of recovery with 4.2.1 but you could with 4.1. The solution was firstly to go to C:\Windows\System32\drivers\etc\ and locate “hosts” file and add the line 74.208.105.171 gs.apple.com at the end (you will have to run with administrator privileges.) Then run redsn0w and tick just enter Pwned DFU mode right now. Once in DFU mode I downloaded a copy of the 4.1 IPSW from here iOS 4.1 IPSW Download Sources - Softpedia ran itunes, pressed restore and shift and located the IPSW file and installed 4.1. You will probably receive the same error message as me when I tried to recover from 4.2.1 (error 1015). Ignore this, shut itunes, exit recovery with TinyUmbrella or as I did recboot and then you should be back into your iphone. Just a matter of then running redsn0w again but pointing to the 4.1 instead of the 4.2, but this time there is no need to tick the ipad bb install just the Cydia as bb is already installed. Hope it helps you as it did me. Write back if any questions.
The Following User Says Thank You to swayzbal For This Useful Post:
Old 12-06-2010, 04:06   #2 (permalink)
SJS
SJS's Avatar
Member: 14684
Thanks Meter: 59
Then run redsn0w and tick just enter Pwned DFU mode , and restore with i tunes: custom firmware. And phone will live again. But not possible to restore from 4.2.1 to 4.1. On sunday was possible, but for now, No.
Old 12-06-2010, 04:15   #3 (permalink)
Member: 1442194
I am actually stuck at this step now.... running redsn0w now... hope i get lucky
Old 12-06-2010, 05:14   #4 (permalink)
Member: 926425
Thanks Meter: 33
stuck on recovery mode
dear
1 use redsnow click firmware 4.2.1
2 tick in redsnow just enter pwned dfu mode right now
3 phone will to black screen and this dfu mode
4 now restore with custom firmware the link is available below
5 now ur phone will come to emergency mode
6 use redsnow again and tick only cydia option
7 ur phone will again hange on apple logo and dont worry
8 just enter boot theater right now
ur phone will come alive and then u can use cydia and can unlock ur phone if ur baseband is upgrade to 6.5.01 and if not then u can use cydia with both option of cydia and install ipad baseband selection and then repeat the above procedure
MEGAUPLOAD - The leading online storage and file delivery service
thanx
khalid khan
The Following 3 Users Say Thank You to faizi_khalid For This Useful Post:
Old 12-06-2010, 05:21   #5 (permalink)
Member: 724260
Sonork: saidarif
Thanks Meter: 66
thanks bro good solution ...................
Old 12-06-2010, 06:45   #6 (permalink)
mccm's Avatar
Member: 173565
Thanks Meter: 71
yes upload to repidshare,mega is too slow thank you.
too many user squeeze juice together
Old 12-06-2010, 07:00   #7 (permalink)
sagar_lse's Avatar
Member: 777523
Sonork: 100.1584558
Thanks Meter: 330
Originally Posted by faizi_khalid View Post
dear
thanx
khalid khan
but after restart same problem any for that
The Following User Says Thank You to sagar_lse For This Useful Post:
Old 12-08-2010, 09:36   #8 (permalink)
Member: 926425
Thanks Meter: 33
stuck on apple logo
brother
can u explain wat u have done with ur phone then i can tell u the solution
or connect me at [email protected]
thanx
khalid khan
Old 12-08-2010, 10:18   #9 (permalink)
Member: 926425
Thanks Meter: 33
i m uploading for on hotfile
thanx
khalid khan
Old 12-08-2010, 10:18   #10 (permalink)
Member: 926425
Thanks Meter: 33
i m uploading for u on hotfile
thanx
khalid khan
Old 12-08-2010, 11:02   #11 (permalink)
Member: 846066
Thanks Meter: 23
but it not working 100/100
this solution is juste for powring phone
you need all time whene you poweroff youre phone it stay in logo aple.and you need to active it with the redsnow.
you mack effort freind
we hope better
thanks
Old 12-08-2010, 11:12   #12 (permalink)
Member: 1461284
tnx very much youre a life saver!!!!!
Old 12-08-2010, 11:21   #13 (permalink)
ZoHaiB_(FoneGSM)'s Avatar
Member: 82666
Sonork: 100.108210
Thanks Meter: 283
just use this Option only in Redsn0w
your phone turn On Normal
Old 12-08-2010, 17:48   #14 (permalink)
Member: 883224
Thanks Meter: 29
here is the solution
http://forum.gsmhosting.com/vbb/f456...mware-1153506/
Old 12-09-2010, 09:31   #15 (permalink)
Member: 926425
Thanks Meter: 33
custom firmware 4.2.1 on hotfile
Hotfile.com: One click file hosting: iPhone2,1_4.2.1_8C148a4.2.1Custom_Restore.ipsw
SW ASIC MISHATCH at 5110 jonwillow Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-29-2001 15:30
Just have a look at ... frenchcortex GSM Mobile Links 0 08-06-2001 18:54
How can I use AT command control Nokia6110?Help me! arnom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-15-2000 07:35
Programmeing tools at www.cellularrepairs.co.uk dave GSM Mobile Links 0 09-09-1999 20:22
Page generated in 0.66767 seconds with 8 queries
