Iphone 3gs camera not working Hello everyone I have this phone which camera was not working. when i click on the camera on the main menu it opens the application but it stays shut with a barrier on it and i cant take picture and anything,everything is disabled. I tried a restore but nothing I replaced the camera with a new one but nothing can someone tell me what can be the problem? thank you |
resolder or replace camera conector........... |
This is the connector and from the picture it as you can see there is nothing wrong with it http://img706.imageshack.us/img706/8...ctormod.th.jpg |
whats it doing.. I had one that was turning the screen green after i replaced it with another camera. I then replaced the new one with another camera and it ended up working. So try another one. my advice |
it writes something when you turn on camera from menu or nothing happens, cause i had a problem with camera, when turning on writes that there is not enough space, and after reflashing all ok! solved! |
it does not write anything you know when on iphone you open the camera application and there is this closed shutter (spiral style) that opens. In my case this shutter stays closed and all the button like taking picture button stays disabled. |
I have same problem like @cpu2007, the problem is somewhere on logic board, and if someone knows the solution pls write. |
Buy new Camera iPhone 3GS Buy new Camera iPhone 3GS Camera Module With Flex Cable OEM Replacemet - iPhone 2G 3G 3GS 4 iPad iPod Replacement ricambi iphone 3gS |
you can try this: http://forum.gsmhosting.com/vbb/f631...-open-1192949/ 3gs is almost identical in that area as the 3g |
Hello everyone I have this phone which camera was not working. when i click on the camera on the main menu it opens the application but it stays shut with a barrier on it and i cant take picture and anything,everything is disabled. I tried a restore but nothing I replaced the camera with a new one but nothing can someone tell me what can be the problem? Thanks |
I did resold that but still doesn't work. do not open shatter. |
Have same issue with no resolve yet. . Connector is fine. camera is fine. What can be done on the logic board of the 3GS to fix this. |
