11-21-2012, 08:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Age: 34
Member: 112302 Status: Offline Thanks Meter: 28 | Iphone 3gs cant restore now i want to restore it via itunes.. itunes downloaded the whole large software , extracted it , then error accired.. "iphone can not be restored..unknown error accrued..error 3194" why my iphone 3gs can not be restored? also when i plug it on charger or on computer , it shows "charging is not supported with this accessory" any help? |
The Following User Says Thank You to atin_garg2005 For This Useful Post: |
11-21-2012, 08:56 | #3 (permalink) |
Member: 112302 Status: Offline Thanks Meter: 28 | i dnt want to update it to 6.0.1 m ok with 5.1.1 as it runs smooth...any way to unjailbreak and restore 5.1.1? |
11-21-2012, 09:04 | #4 (permalink) |
Member: 112302 Status: Offline Thanks Meter: 28 | when i connect my phone to wall charger or computer or laptop, why my phone shows "charging is not supported with this accessory" |
11-21-2012, 11:27 | #5 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Ireland&Uk Age: 34
Member: 1624620 Status: Offline Thanks Meter: 751 | you need first to have shsh files saved if you want to restore to 5.1.1 Make a custom firmware with redsnow 0.9.14.b2 And select that custom If you receive the same error go to C:\WINDOWS\system32\drivers\etc edit the host file (delete the last lines with gsm.apple) and try again About that msg check cable or charger port I have many with that problem but after restore doesn't show that msg Br FLoryneL |
The Following User Says Thank You to florynel_gsm For This Useful Post: |
11-23-2012, 14:47 | #8 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 433 | use redsn0w to get shsh from iphone. you'll get a 709a07a1c608fb8a17febbb4a4b0ca7da89abcf9.plist similar file in c:\users\yourusername\.shsh\.known_devices. Use that file to sign 5.1.1 firmware (with same redsn0w) and your ready to restore to same version. Already tested with iphone 3gs and not sure if with iP4. Br. |
11-23-2012, 18:29 | #9 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Online Sonork: 100.1595099 Thanks Meter: 527 | Quote:
want to upgrade ver 5.1 to 5.1.1 and unlock it before all passed ok but now only error 3194 Best regards | |
11-23-2012, 18:35 | #10 (permalink) | |
Member: 1624620 Status: Offline Thanks Meter: 751 | Quote:
But is verry verry verry hard to do this ......... http://forum.gsmhosting.com/vbb/f456...-shsh-1544743/ Br FLoryneL | |
11-23-2012, 19:37 | #11 (permalink) |
No Life Poster Join Date: Feb 2011 Location: United Kingdome
Member: 1507640 Status: Offline Thanks Meter: 131 | bro first thing you want to downgrade or upgrade if you want to downgrade only you can do on 4.1 if update then only latest version which is 6.0.1 if its giving error 3194 while upgrading use tiny umbrela to fix it from here tinyumbrella-6.01.01.exe download it run it go in advance tab close it and restart your pc after this do you upgrade it will be fine. |
11-23-2012, 20:33 | #12 (permalink) | |
Member: 112302 Status: Offline Thanks Meter: 28 | Quote:
when i clicked fetch shsh , it gives error "unrecognized build. fingerprint e71efe9b...bla bla please check if u have latest version or ios version is supported or not.. i am running ios 5.1.1 what to do now? | |
11-23-2012, 21:08 | #13 (permalink) |
Member: 112302 Status: Offline Thanks Meter: 28 | i have got my shsh for 5.1.1 through cidya and shsh-it app on iphone 3gs i emailed my 5.1.1 shsh and saved dem on my pc i downloaded redsnow but i cant stitch my shsh to my ios 5.1.1 firmware when i stitch , it gives error"The blobs could not be verified" any sugession? |
11-23-2012, 21:10 | #14 (permalink) | |
Member: 478535 Status: Offline Thanks Meter: 433 | Redsn0w 0.9.15b3 Use this version, the latest. Get 5.1.1 ipsw for 3gs. On redsn0w, go to extras-select ipsw->point to dowloaded 5.1.1 3gs ipsw. then extras-shsh blobs-fetch. then Extras-even more-restore. Br edit: Quote:
11-23-2012, 22:26 | #15 (permalink) |
Member: 112302 Status: Offline Thanks Meter: 28 | i clicked on restore , 1. selected my ipsw 2. den selected shsh files for restore restore completed 100% but phone stuck on recovery mode when i click fix recovery mode , it downloads jailbreak data and returns to recovery mode... what to do now? |
