08-03-2011, 09:22 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | iphone 3gs cnt restore |
08-03-2011, 15:57 | #12 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Lebanon Age: 36
Member: 1424719 Status: Offline Sonork: 100.1619833 Thanks Meter: 2,563 | This problem is due to a bug in Cydia’s back end . To resolve iTunes error 3194 and be able to upgrade your device to the stock iOS 4.3.3 or a custom iOS 4.3.3, Do these steps: 1.Download TinyUmbrella for windows or TinyUmbrella for mac. 2.Launch TinyUmbrella and select “Advanced” then uncheck “Set Hosts to Cydia on Exit” option. 3.Click on “Start TSS Server”. 4.Now you should see Green Check Mark + “TinyUmbrella’s TSS server is running” . 5.Now Connect your iDevice to the computer and launch iTunes while keeping Tiny Umbrella Running. 6.Hold the Shift Key and Click on Restore in iTunes and browse for the IPSW file, Now you should not face the 3194 error. Br, Axecom |
The Following 4 Users Say Thank You to axecom For This Useful Post: |
08-04-2011, 08:46 | #13 (permalink) | |
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
08-04-2011, 08:55 | #14 (permalink) |
Member: 1424719 Status: Offline Sonork: 100.1619833 Thanks Meter: 2,563 | To fix DFU mode after doind the steps above: First thing you will need to do is to download the following files: 1.TinyUmbrella (FixRecovery) for windows Zlib1.dll LINK: zlib1.zip Now just follow the steps below: 1.Create a new folder name it anything you like and save both files downloaded earlier in this folder. 2.Unzip both files (Right click on the file and extract). 3.Launch iTunes and plug your iPhone into your computer. 4.Put your iPhone in DFU mode following the steps below: Hold down the Home+Power button simultaneously for 10 seconds. After 10 seconds, release the Power button but keep holding the Home button until iTunes detects your iPhone into DFU mode. Do not close iTunes. Let it run in the background. 5.Launch fixrecovery43.exe and just wait for it get your iPhone out of recovery mode.Make sure you have an active internet connection because fix recovery will be needing to fetch DFU and firmware image from Apple servers. When you see Exiting libpois0n in terminal window, you can disconnect your iPhone from your computer. Rest of the procedure will done on your iPhone. This process should not take more than 2 minutes. Br, Axecom |
The Following 2 Users Say Thank You to axecom For This Useful Post: |
Help me restore dead C35 with AMD Flash (flash HC B701)!!!!!Please!!!!!! | razor | x1x to x45/x50 | 0 | 11-29-2001 09:13 |
Downloads restored :) | GSM_guru | GSM Mobile Links | 0 | 11-25-2001 16:24 |
Help to restore Siemens A35 ver.13. | SergeyM | x1x to x45/x50 | 0 | 11-24-2001 19:26 |
how to restore A36, destroyed with wrong unlock? | sat | x1x to x45/x50 | 0 | 10-13-2001 16:59 |
HEX for CLIP to restore Factory Defaults | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2000 15:59 |
