01-12-2011, 02:09 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: on the earth
Member: 1491073 Status: Offline Sonork: 100.1608050 Thanks Meter: 49 | iphone 3gs needs help please i have iphone 3gs was unlock (tetheret) no (SASH saved )but there is no network i tried to flash it again but big problem happened i tried LOT OF ways and i have read all post but no solution when i used redsn0w it stuck of recovery mode i used alot of program to fix it but no way i used itunes also come error 1015 at recovery mode please any solution |
01-12-2011, 02:13 | #2 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1263932 Status: Offline Thanks Meter: 181 | Please provide this info: - what firmware version is installed and what firmware version do you want to install? - what baseband version is installed? - run TinyUmbrella and backup all shsh. Tell what versions get listed. |
The Following User Says Thank You to https For This Useful Post: |
01-12-2011, 02:25 | #3 (permalink) |
Member: 1491073 Status: Offline Sonork: 100.1608050 Thanks Meter: 49 | thanks for answer it have had OS 4.2.1 and i want restore it again because no way to downgrade because i dont have saved SHASH baseband 6.15 |
01-12-2011, 02:34 | #5 (permalink) |
Member: 1491073 Status: Offline Sonork: 100.1608050 Thanks Meter: 49 | i used redsn0w_win_0.9.6b6 to jailbreake it with OS 4.2.1 but it stuck at recovery itunes i used tinyumbrella-4.21.02 to fix it but make restore and again stuck at recovery itunes i used (iPhone2,1_4.2.1_8C148a4.2.1Custom_Restore.ipsw) with itunes also error 3194 any solution please |
01-12-2011, 02:43 | #7 (permalink) |
Member: 1263932 Status: Offline Thanks Meter: 181 | It takes a few minutes. Look at the log tab. Your device must be connected. Run as administrator. Allow firewall exception. Disable virusscanner if necessary. Then retry. You have to get at least one shsh backup. Tell me which versions it found. |
01-12-2011, 06:05 | #10 (permalink) |
Freak Poster Join Date: May 2007
Member: 504557 Status: Offline Thanks Meter: 23 | Easy Steps * 1. Run Redsn0w 0.9.6b5. 2. Browsing & select 4.1 or 4.2 firmware. 3. The new message box will pop up so click YES. 4. Click next. 5. just enter pwned DFU mode right now. 6. then open itunes 10.1 7. shift and select oficial frimwar 4.1.restor.u got error 1015 nd iphone already in recocery 8. open RecBoot. _V 1.1 Run Exit.Bat . it will complete and screen Emergency Call Mode. 9. Run Redsn0w 0.9.6b5. 10. Browsing & select 4.1 firmware. 11. The new message box will pop up so click YES. 12. Click next. 13. don't tick install ''updat ipad basebande''.only ''instal cydia'' done .complete and screen Airplane Mode. 14. Again Open Redsn0w 0.9.6b5. 15. Browsing & select 4.1 firmware 16. The new message box will pop up so click YES 17. Click next 18. Check on INSTALL CYDIA and INSTALL IPAD BASEBAND 19. Again new message box will pop up so click YES 20. Click next 21. Follow introduction for DFU 22. Jailbreak Done ! 23. Extract Unlock 06.15 Without wifi and open Unlock.bat 24. Reboot Device 25. Unlock Done ! |
The Following User Says Thank You to fundi muddy For This Useful Post: |
01-12-2011, 13:45 | #14 (permalink) | |
Member: 1263932 Status: Offline Thanks Meter: 181 | Quote:
Some comments about this: - latest official redsn0w is 0.9.6rc8 - step 7 will only work if you previously ran TinyUmbrella or your host file is modified AND you have backup of SHSH for 4.1 on Cydia. If this worked, you have SHSH backup for 4.1! - step 18: user has 6.15 already, so not necessary - etc. overall too complicated, but might work | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
