Old 11-11-2009, 03:14   #1 (permalink)
Member: 452892
Thanks Meter: 104
iPhone 3Gs show: "Charging is not supported with this accessory" on screen
hi all! my iphone show this message on screen: "Charging is not supported with this accessories", but phone still make call, wifi ok, charge with usb or dock ok, all are ok...but i dont know reason why phone shows that message on screen...how could i remove this message? plz any solution?
--->>>SOrry for my bad english...
Old 11-11-2009, 03:25   #2 (permalink)
Member: 127049
Thanks Meter: 49
maybe water .
try to plug in and out head set jack, clean charger connect with alcohol
hope it work
Old 11-11-2009, 03:31   #3 (permalink)
Member: 452892
Thanks Meter: 104
Originally Posted by dienson View Post
maybe water .
hope it work
thanks bro...i had done but no better...maybe my guest uses the iphone with carkit so it take to this problem???
Old 11-11-2009, 03:45   #4 (permalink)
armany99's Avatar
Member: 85637
Sonork: 100.100.529
Thanks Meter: 139
hi my friend
i think if u have try to connect to car kit i think
its not work with your phone so make this problem
soo try to restore your phone
if its work that fine if not try to clean charge connecter
and post reply
maybe water .
hope it work
thx for your post
but he ask here about charging not supported
not for speaker or headset problem
The Following User Says Thank You to armany99 For This Useful Post:
Old 11-11-2009, 04:00   #5 (permalink)
Member: 378053
Thanks Meter: 97
Use original Cable ang charger adaptor
The Following User Says Thank You to dtdd_ansuong For This Useful Post:
Old 11-11-2009, 06:42   #6 (permalink)
Member: 452892
Thanks Meter: 104
thanks for replying all bro. but my phone's working well, phone still charges ok...still make call well. and test wifi well.but when i unplug cable on phone's screen will show me that messages...i try to restore but the same problem
Old 11-11-2009, 06:51   #7 (permalink)
Member: 496243
Thanks Meter: 42
Arrow
Try to use another original charger and it'll be fine
Regards
Old 11-11-2009, 19:35   #8 (permalink)
Member: 127049
Thanks Meter: 49
if still get that messages after you done all above,
open iPhone take out the board off battery , wait some minutes, put it back then plug in charger,
hope it okie
with me your phone dirty or moisture, try to clean on charger connector ( I fix this so many times for my customer 0
The Following User Says Thank You to dienson For This Useful Post:
Old 01-18-2010, 06:37   #9 (permalink)
miguel_john1975's Avatar
Member: 586346
Thanks Meter: 113
i had same problem
tried to search the google
and many has thesame problem
http://discussions.apple.com/thread....art=30&start=0
http://scosche.com/products/productID/1667
http://forums.macrumors.com/showthread.php?t=339988
http://forums.ilounge.com/archive/in.../t-236842.html
http://www.fashion-res.com/charging-...his-accessory/
http://www.cablejive.com/iphone_3g_c...converter.html
http://discussions.apple.com/thread....15874&tstart=0
and more....problem to come
for info only
The Following 2 Users Say Thank You to miguel_john1975 For This Useful Post:
Old 04-21-2010, 19:31   #10 (permalink)
Member: 458909
Thanks Meter: 33
I had the same problem. Solved by replacing charging connector with flex.
Old 04-22-2010, 02:55   #11 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
just replace the USB socket full flex your problem should be ok.
thanks
Old 04-22-2010, 03:57   #12 (permalink)
Member: 830204
Thanks Meter: 21
Hi, my friend! Please test this method:
1. go to and download http://www.huanix.com/iapd (direct download)
2. Use iPhoneExplorer or SSH to iphone and navigate to this /System/Library/PrivateFrameworks/IAP.framework/Support/
3. copi the iapd in Support,reboot and you have the sound
OR
terminal or putty to iphone and taip thishit enter after each line)
cd /System/Library/PrivateFrameworks/IAP.framework/Support/
mv iapd iapd.broken
wget http://www.huanix.com/iapd
chmod 755 iapd
chown root:wheel iapd
exit
exit
I tested 2 iPhones 3g and it work fine.
Don't 4get say thanks
Old 04-23-2010, 00:48   #13 (permalink)
Member: 288858
Thanks Meter: 2
i fixed more then 5 phone with same problem , change the charging connector
Old 08-24-2010, 22:13   #14 (permalink)
Member: 1377715
OR
mv iapd iapd.broken
chmod 755 iapd
exit
exit
Hi Hopes Every Thing Is Fine At your End
And First Of All Thankyou To Be A Volunter In This webSite.
I Am Facing the same problem with my iphone 3gs 32gb
Charging Is Not Supported with this Accessory.
And i dont know how to troubleshoot with this and i had seen your foroum but i still dont know how to solve this
can u please explain me step by step please
i will be very thank full to you
because i dont know iphone explorer and ssh to iphone
and wher should i download this go to and download http://www.huanix.com/iapd (direct download) in my iphone or in my pc
please Brother REplly me with step by step
I Am Sincerly WSaitting for your reply
Thanks & Regards.
Fazal
Old 08-24-2010, 22:15   #15 (permalink)
Member: 1377715
Thanks & Regards.
Fazal
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 21:38
bb5+ is NOT supported by this tool?? konj12 Cyclonebox 6 07-02-2009 02:48
Error. This HASH is not supported yet! with UFS Thread Logitext Nokia Base Band 5 ( BB-5 ) 0 12-18-2008 16:59
V235 Unlock is not supported for this firmware version cubafreak Smart-Clip 4 08-17-2006 21:24
V3i Rogers Unlocking phone... Unlock is not supported for this firmware version jacsha Smart-Clip 2 05-31-2006 20:01
Page generated in 0.43333 seconds with 8 queries
