06-01-2013, 09:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 541592 Status: Offline Thanks Meter: 45 | Iphone 4 (-1) solution , easy flash 1.Download ifath 1.5.8 2.dump bloobs 6.1.3 3.buld firmare -select bloobs , and firmware 6.1.3 4.ireb DFU pwner 5.restore use itunes and select singned ipsw(bulded firmware) |
The Following 17 Users Say Thank You to Ishxan For This Useful Post: |
06-03-2013, 13:48 | #2 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1500893 Status: Offline Thanks Meter: 1 | good work its working.. but if anyone test with this step then failure .. maybe is BB IC low power .. its hardware problem.. |
The Following User Says Thank You to irzhan For This Useful Post: |
06-04-2013, 11:58 | #9 (permalink) | ||
Registered User Join Date: Mar 2013 Location: pakistan
Member: 1901604 Status: Offline Sonork: 100.1622736 Thanks Meter: 72 | Quote:
i know its hardware problem but some phones not comlete restore similerly this solution is the best for iphone comlete restoring | ||
06-05-2013, 13:35 | #12 (permalink) |
Junior Member Join Date: Jul 2009 Location: Afghanistan
Member: 1069610 Status: Offline Sonork: 1623689 Thanks Meter: 6 | 1 Error of Hardware failure . it actually comes when Baseband (IMEI) of the IPhone corrupted . you have no option rather than replacing the iphone or Change the logic board inside. if you are using the mac then connect the phone in recovery mode and go to system profiler and then go to usb then select the iphone .this will show the serial number there . if the serial number show ffffffffffffffff like this then change the phone . otherwise we can try to recover the iphone . |
The Following User Says Thank You to ziahafid For This Useful Post: |
06-06-2013, 09:05 | #13 (permalink) | |
Member: 541592 Status: Offline Thanks Meter: 45 | Quote:
06-06-2013, 12:37 | #14 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | restore error -1 its a hardware problem for iphone 4 or 4s |
