Old 07-22-2011, 17:55   #1 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 131
iphone 4.3.4 downgrade to 4.1
hi
did someone have 100% solution to downgrade iphone 4.3.4 to 4.1 and getting it working not in recovrey mode
thx
Old 07-22-2011, 17:57   #2 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 545
ONLY if you have 3gs!!!
Old 07-22-2011, 18:32   #3 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 712
yes u can downgrade because 4.1 its not signed.... only works for iphone 3gs!
Old 07-22-2011, 18:59   #4 (permalink)
ahmertelecom's Avatar
Member: 210880
Sonork: 100.1577765
Thanks Meter: 146
can u tell me how can do this thnx
Old 07-22-2011, 19:14   #5 (permalink)
Member: 1588686
Thanks Meter: 24
Originally Posted by patric View Post
hi
thx
test my method and post result after .
needed for this operation
1 - iphone 3gs old or new boot ver 4.3.4
2 - a good and working brain
3 - TinyUmbrella last version
4 - stock firm 3gs 4.1
5 - irep r4
6 - itune
ok . all is ok
1 -put your iphone in pwd dfu mode by using irep r4
2 -start tinyumbrella and start tss server .
3 - lunch itune and choise stock firm 4.1 and restor you iphone
4 - after you have restoring your iphone its stuck in dfu mode
5 - jailbreak your iphone by using redsnow and choise 4.1 firm
6 - after you have iphone stucked in activate in jailbreak process
7 - puch power and home for reset iphone
8 - your iphone now in dfu mode again
9 -by using redsnow choise firm 4.1 and select boot tethered
10 - your iphone power and go to recovery mode
11 - by using tyny ambrella exit recovery mode
12 -now your iphone is in dfu mode
13 - power your iphone by redsnow boot tethered
14 -now your iphone is power on and deactivated
15 - activate your iphone if you have a valid sim card .if no repeat pocess jailbreak and boot tethered
16 - now you have iphone activated and cydia installed
17 - start tyny ambrella and save shh and disconnect iphone
18 - in iphone lunch cydia and wait for tss que
19- after tss Que is ok .power off your iphone .0 its go to dfu mode
20- launch tss server in tyny ambrella software . and restore again by using 4.1 ( not using irep to pwd iphone ))
21- itune stuck in error 1015 . after that exit recovery mode by using tyny ambrella
22- jailbreak iphone again and install base band and unlock it
for redsnow use redsn0w_win_0.9.6rc17
Old 07-23-2011, 10:54   #6 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 131
5 - irep r4
6 - itune
ok . all is ok
i test your method
phone go into recovrey mode not dfu mode after upgrade
Old 07-23-2011, 13:15   #7 (permalink)
Member: 1588686
Thanks Meter: 24
ok . if after upgrade have a phone in recovry mode . use tyny ambrella for exit recovry mode . and after jailbreak it . post result
Old 07-23-2011, 15:45   #8 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 131
can't get out of recovrey mode!!!!
Old 07-23-2011, 15:55   #9 (permalink)
.::LUQMAN::.'s Avatar
Member: 413053
Sonork: 100.114351
Thanks Meter: 457
5 - irep r4
6 - itune
ok . all is ok
i realy need tested feedbak......bcoz i tried but not works
Old 07-23-2011, 16:29   #10 (permalink)
Redknight07's Avatar
Member: 1478277
Thanks Meter: 41
BRO......I will give u solution.....Tested by me...........
U need custom firmware that created by Pwnage tool 4.2.1.......of ur 4.1 3gs FW........
And Restore it with this FW and u will be ok bro......
SO SIMPLE....
Redknight07
Old 07-23-2011, 16:44   #11 (permalink)
GSMsurgeon's Avatar
Member: 6524
Thanks Meter: 241
your phone is 3gs?
if 100% work.. just downgrade then phone will be recovery mode..then just use tinyumberla for exit recovery..then use limerain for jailbrack then use ultrashow for unlock(if unlockable baseband)
i have done many 3gs !!!
Old 07-23-2011, 21:06   #12 (permalink)
Member: 149041
Sonork: 100.114578
Thanks Meter: 61
iphone 4 4.3.4 any idea to down 4.3.3 without SHSH file??
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 03:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.34088 seconds with 8 queries
