11-29-2012, 19:21 | #1 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1846215 Status: Offline Thanks Meter: 1 | Iphone 4 6.0.1 no signal after ultrasnO and problem with SHSH I have iphone 4 firmware 6.0.1 and BB 01.59.00 and i install ulstrasnOw fixer then normal ultrasnOw. But i still don't have signal,sometimes appear one unit. Wifi works fine. Later i have firmware 4.3.1 with jailbreak but now i don't have saved SHSH(for this firmware). it appears only for ios 6.0.1 in cydia .I know i need to save it but in other devices i don't have this problem. I try to get this SHSH from tinyumbrella 6.0.1 but still no postive results. Could anyone help me with get this SHSH or how to repair this ultrasn0w? |
11-30-2012, 02:41 | #2 (permalink) |
Junior Member Join Date: Apr 2004 Age: 49
Member: 62887 Status: Offline Thanks Meter: 4 | Was the 4.3.1 SHSH saved by tinyumbrella in 2010? Was the 4.3.1 SHSH saved by redsnow while it was installed on the phone? If it's no to both then forget about 4.3.1, it's not coming back for that phone. Sounds like you only have access to 6.0.1 with tethered jailbreak. Have you tried installing ultrasn0w first then ultrasn0w fixer second? You may need to install 6.0.1 with No Baseband update and try again to be sure. |
11-30-2012, 02:50 | #3 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 743419 Status: Offline Sonork: ranz_28 Thanks Meter: 42 | you cannot downgrade it without save shsh blobs..... try to install crack games and check if games are working if not try to install appsync and try tp reinstall ultrasnow fixer and ultrasnow.... |
11-30-2012, 05:22 | #4 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Inside the World
Member: 1835240 Status: Offline Sonork: 100.1624260 Thanks Meter: 26 | bro no need to install ultrsnow fixer.... u need to install ultrsnow... then reboot iphone... u need to save shsh blob then u can downgradeit via itunes broo........ |
11-30-2012, 12:50 | #6 (permalink) |
Member: 1846215 Status: Offline Thanks Meter: 1 | I install first fixer and then normal ulstrasn0w, and i do this few times but signal is still low. also i cleen network settings. I try to get shsh from tiny umbrella from few versions but only avaible is 6.0.1. So only way is repair the 6.0.1 . i will try install custom firmware 6.0.1 and then install fixer+ulstrasn0w but i don't think if it help. Any other guess? |
12-09-2012, 03:19 | #8 (permalink) |
Member: 1835240 Status: Offline Sonork: 100.1624260 Thanks Meter: 26 | install ipad baseband bro then downgrade it to 5.13 baseband.... |
The Following User Says Thank You to sjd012 For This Useful Post: |
12-09-2012, 04:44 | #9 (permalink) |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | Use latest tiny umbrella to get your SHSH but look in cydia if there you found then you can save by tiny umbrella. G S M - D O C T O R |
The Following User Says Thank You to GSM-DOCTOR For This Useful Post: |
