11-20-2014, 20:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Pakistan Age: 32
Member: 1378233 Status: Offline Sonork: 100.1594197 Thanks Meter: 195 | iphone 4 activation error after itunes |
11-20-2014, 21:15 | #2 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | This is because you wifi is not working. 1st repair wifi then it will be ok 100% http://forum.gsmhosting.com/vbb/f456...00004-1862733/ |
11-20-2014, 21:53 | #3 (permalink) | |
Member: 1378233 Status: Offline Sonork: 100.1594197 Thanks Meter: 195 | Quote:
11-21-2014, 02:25 | #4 (permalink) |
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | no wifi activate phone itune possible |
11-23-2014, 10:07 | #8 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | 1st check ur phone wifi its neet board do not show any problem like looking mianboard leave this do not touch for wifi ic 2nd this is apple company tecnical isshu |
11-23-2014, 10:59 | #9 (permalink) |
Moderator Join Date: Jan 2011 Location: Throne of GsmHosting
Member: 1483853 Status: Offline Sonork: 100.1611111 Thanks Meter: 1,628 | To activate your device , insert a sim card in your phone , open itune and connect your phone with Pc using USB cable after sec's it will b unlocked. To bypass ios 7.1.2 there are many guides out , you can use any of em it will activate your device so u can use it as ipod one of the guide is shown in this post: http://forum.gsmhosting.com/vbb/10290837-post3.html To retrieve your wifi you need to check wifi ic and if itune fails to activate and you use activation bypass then go to setting>general>about and check imei if u have imei then restore once again and try to activate ,If there is no IMEI then ur baseband ic is bad u need to replace it or u can use phone as ipod hit thanks to show respect |
11-23-2014, 12:18 | #11 (permalink) | |
11-23-2014, 12:58 | #13 (permalink) |
Freak Poster Join Date: Apr 2012
Member: 1745548 Status: Offline Thanks Meter: 85 | if you have saved SHSH BLOBS just downgrade it using Redsn0w bro, lucky to have Saved SHSH BLOBS then i just downgrade it from 7.1.2 to 5.1.1 then activate it using iTunes Latest Version and it 100% works Signal = SMS/CALL but WiFi is disabled due to Wifi IC Damage |
11-23-2014, 14:43 | #14 (permalink) | |
Member: 1483853 Status: Offline Sonork: 100.1611111 Thanks Meter: 1,628 | Imei is ok in phone ? Quote:
Can u please explain , may b i missed something. | |
