Old 11-20-2014, 20:51   #1 (permalink)
qasim_riaz's Avatar
Member: 1378233
Sonork: 100.1594197
Thanks Meter: 195
iphone 4 activation error after itunes
I restored my iPhone 4 from iTunes and when trying to activate it, I get the message Error 0xE80000004. I can not activate my iPhone 4 using wifi connection because asks me directly connect to iTunes and after displaying the error is not activated
Old 11-20-2014, 21:15   #2 (permalink)
Registered User
Member: 115596
Thanks Meter: 1,127
This is because you wifi is not working. 1st repair wifi then it will be ok 100%
http://forum.gsmhosting.com/vbb/f456...00004-1862733/
Old 11-20-2014, 21:53   #3 (permalink)
qasim_riaz's Avatar
Member: 1378233
Sonork: 100.1594197
Thanks Meter: 195
butt without wifi activate phone itune possible
Old 11-21-2014, 02:25   #4 (permalink)
Registered User
Member: 115596
Thanks Meter: 1,127
no wifi activate phone itune possible
Old 11-21-2014, 13:34   #5 (permalink)
qasim_riaz's Avatar
Member: 1378233
Sonork: 100.1594197
Thanks Meter: 195
wifi ic damage not possible wifi repair
any other solution phone activat
Old 11-21-2014, 15:01   #6 (permalink)
asilaydying2012's Avatar
Member: 1745548
Thanks Meter: 85
just downgrade it bro if you have Saved SHSH BLOBS, done it successfully with the same error due to Wifi IC Damage
Old 11-23-2014, 06:04   #7 (permalink)
qasim_riaz's Avatar
Member: 1378233
Sonork: 100.1594197
Thanks Meter: 195
11.0 itune not working
Old 11-23-2014, 10:07   #8 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
1st
check ur phone wifi its neet board do not show any problem like looking mianboard
leave this do not touch for wifi ic
2nd this is apple company tecnical isshu
Old 11-23-2014, 10:59   #9 (permalink)
Moderator
Sitlay KING's Avatar
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,628
To activate your device , insert a sim card in your phone , open itune and connect your phone with Pc using USB cable after sec's it will b unlocked.
To bypass ios 7.1.2 there are many guides out , you can use any of em
it will activate your device so u can use it as ipod
one of the guide is shown in this post: http://forum.gsmhosting.com/vbb/10290837-post3.html
To retrieve your wifi you need to check wifi ic and if itune fails to activate and you use activation bypass then go to setting>general>about and check imei if u have imei then restore once again and try to activate ,If there is no IMEI then ur baseband ic is bad u need to replace it or u can use phone as ipod
hit thanks to show respect
Old 11-23-2014, 12:07   #10 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
its not software its hardware problm
check wifi ic
Old 11-23-2014, 12:18   #11 (permalink)
qasim_riaz's Avatar
Member: 1378233
Sonork: 100.1594197
Thanks Meter: 195
i chek this solution butt sim not working
Old 11-23-2014, 12:19   #12 (permalink)
qasim_riaz's Avatar
Member: 1378233
Sonork: 100.1594197
Thanks Meter: 195
check wifi ic
Old 11-23-2014, 12:58   #13 (permalink)
Member: 1745548
Thanks Meter: 85
if you have saved SHSH BLOBS just downgrade it using Redsn0w bro, lucky to have Saved SHSH BLOBS then i just downgrade it from 7.1.2 to 5.1.1 then activate it using iTunes Latest Version and it 100% works Signal = SMS/CALL but WiFi is disabled due to Wifi IC Damage
Old 11-23-2014, 14:43   #14 (permalink)
Moderator
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,628
Imei is ok in phone ?
what the point of activating a device on 5.1.1 instead of 7.1.2
Can u please explain , may b i missed something.
Old 11-23-2014, 17:50   #15 (permalink)
qasim_riaz's Avatar
Member: 1378233
Sonork: 100.1594197
Thanks Meter: 195
how to downgrade ios 7.1.2 to ios 5.1.1
I have SHSH Blobs butt restore error 9 itunes 12.0.1
Page generated in 0.23611 seconds with 8 queries
