iPhone 4 after restore with custom 4.2.1 stuck on Recovery i use this method http://forum.gsmhosting.com/vbb/6816808-post3.html after that use tiny v.4.21.11 but always restart in recovery :/ |
Donot Flash By Custom Just Use Umbrella Save SHSH And Press TTs Server Restore Will Give U Error And Not Update B.B And Stuck On Recovery Use GreenPoison To JB And Exit Recovery Mode And IF After Phone Work Get (Slide To Emrgency ) Mean Not Activated Use RedSn0wRC8 To Make Activate And Install Cydia Now U Have 4.2.1 And Old BB To Unlock And Unthered Regards B,R |
why do you need to flash .And second question is your iphone 4 factory unlocked if it is'nt so i never suggest you to do this untill release of unlock for 4.2.1 |
Use this Custom FW. after restore acitve and use greepois0n to jailbreak http://forum.gsmhosting.com/vbb/f456...-need-1209761/ have funs |
use just custome 4.2.1 its the save way of preserving bb just put your fone in dfu mode using readsn0w after geting phone in dfu mode unplug the usb cable and reconnect it open the itunes and while holding shift key(window) press restore>nevigate the .ipsw path laeve the phone to its last stage,wfter getting 1015 error simply open tiny umberella and kick out of recovery at the same time open readsn0w and when iphone show apple logo at that stage you should jailbreak it waith redsn0w if there is eror repet the procedure at last instal you have to again jailbreak it with greenpoison[to fix the stuck apple logo error] finally after oll this install cydia and then instal ultrasn0w1.2 its oll about say thanks if it helps br sitlay |
well sir i have only one question does green poision work with iphone? i tried savral time but did not get success my phone is still running unthreten |
