05-11-2013, 08:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | iphone 4 after update with 6.1.3 then wifi issue wifi on but wifi connections not show wifi address correct showing |
05-11-2013, 10:54 | #7 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | a4service what u mean about wifi antenna ? i have same problem and all i know about wifi have crystal ic and i rehot it but befor it was not geting signal after rehot its showing with low signal i think it need change |
05-11-2013, 11:08 | #8 (permalink) |
Crazy Poster Join Date: Jan 2013
Member: 1876558 Status: Offline Thanks Meter: 6 | I've found with weak signals on the iPhone 4 just changing the wifi flex usually resolves the problem. Here's the part you require iPhone 4 WiFi Connector Flex Cable | A4Service.co.ukA4Service.co.uk |
05-11-2013, 12:57 | #10 (permalink) | |
Freak Poster Join Date: Oct 2005 Location: KM64tw Age: 37
Member: 187149 Status: Offline Sonork: 100.1611848 Thanks Meter: 33 | Quote:
@MOHIT_THAREJA, better open the phone, check wifi antenna, contacts, screws.... Also remove the shield of the wifi module and check for oxid..... If you will search a bit on the forum you will find a lot of solutions with pictures..... | |
The Following User Says Thank You to M_Alin For This Useful Post: |
05-11-2013, 13:21 | #11 (permalink) |
Member: 1876558 Status: Offline Thanks Meter: 6 | Why should I be banned? If I've broken any rules then I apologise, only trying to resolve this problem. You've practically suggested the same solution to mine but with around 4 hours extra work! |
05-11-2013, 15:06 | #12 (permalink) | |
Dont create misunderstandings, what you post is not wifi antenna! If you want to speak more lets do it private. Sorry to the other members for creating little spam. Is more and more dificult to acces the corect information because of people like you! | |
05-11-2013, 15:35 | #13 (permalink) |
Member: 1876558 Status: Offline Thanks Meter: 6 | I'm sorry, you are talking nonsense. I suggested changing the wifi flex. If you read my post I said I had dealt with the problem many times, being a repair center i do, hence my post to the part. It's not advertising simply a picture of the part, I could have selected any part from google images but since I have the part on my own site and know the URL i chose to display it. If the OP doesn't want to take my advice then that's fine. But you Sir have a stick or something up your rectum and choose to flame people for only trying to help. Good day Sir, I'll leave this topic alone. |
