Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-18-2014, 16:27   #31 (permalink)
Member: 273045
Thanks Meter: 14
This is because no wifi. you have to repair wifi then it will be ok. 100%
Old 09-20-2014, 04:16   #32 (permalink)
Member: 1246625
Thanks Meter: 21
I got the same problem after restored to ios 7.1.2 cannot activate and error 0XE800004 occured. There was no wifi to activate via wifi. The satus of my iphone before was disabled. Any help please...
br
Old 09-21-2014, 20:43   #33 (permalink)
Member: 1520821
Sonork: 100.1641523
Thanks Meter: 40
br
me face the same prblm 2 days before what i do it reheat the wifi ic and suddenly connect with itunes my luck its come okk....u can try this method
Old 09-22-2014, 02:00   #34 (permalink)
Member: 2242386
Thanks Meter: 7
Hello, Guys I Have the same problem with an iPhone which was working very well and is originally unlocked but Can not activate with iTunes it shows the code : 0XE800004
Old 09-22-2014, 02:22   #35 (permalink)
Member: 2242386
Thanks Meter: 7
Well! I think we four or 3 people who have this problem, I think should use an older Version of iTunes or using a Macintosh system. so my friends don't waste your time with hardware problems... we have something in Commun and is we have the problem of "No Wifi" and "0XE800004" so I will try some of my sollutions.
Same Problem for other people in the forum sorry I can't put links i'm new
Old 09-22-2014, 04:35   #36 (permalink)
Member: 112760
My version of iTunes is up to date and my S.O. is Windows 7 Ultimate SP1 is also updated. This error comes from iOS 7.1.2 if you downgrade to iOS 6.1.3 this problem with activation disappears, but the problem with the wifi connection persists. iOS 7.1.2 modifies something in the iPhone 4 that causes this error.
Old 09-22-2014, 05:38   #37 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
Your phone problem obviously hardware provlem but this is sw section
Thread moved to hw section
__________________
USE "THANKS" Button.
Follow Forum Rules
OFFLINE and Away
Old 09-22-2014, 07:24   #38 (permalink)
Member: 2193217
this is a software problem, because I downgraded to 6.1.3 & I could active it through itunes
who has SHSH,able to downgrade
Apple stop's active these iphone with wifi broblem for some reasons
Old 09-23-2014, 10:57   #39 (permalink)
Member: 2242386
Thanks Meter: 7
Good Job : Crzuer-u3
it seems like a software problem...
The Following User Says Thank You to fathiaex For This Useful Post:
Old 09-23-2014, 15:59   #40 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
So when you install ios 7 you can activate your phone ?
Sent from my iPhone using Tapatalk
__________________
Follow Forum Rules
OFFLINE and Away
Old 09-23-2014, 19:28   #41 (permalink)
Member: 2193217
no,I can't
I tried 2-3 iphone 4 (no WIFI)
Apple doesn't active these phones anymore on iOS7
but if you saved SHSH,you can downgrade easy & able to active it via itunes
even you didn't have SHSH ,you can downgrade but get tethered jailbreak
so 3 options for who has iphone 4 no wifi
1- downgrade to ios 6.1.3 if you have SHSH with signal
2- hacktive ios 7 and use it like ipod, no signal
3- if you didn't save SHSH,downgrade it to ios 6.1.3 get signal but (tethered jailbreak)
Old 09-24-2014, 14:00   #42 (permalink)
gwlime's Avatar
Member: 1493085
Sonork: n/a
Thanks Meter: 92
same problem
iPhone 4 [3,2]
i cant activ my iPhone
Old 09-26-2014, 22:24   #43 (permalink)
..::khaled::..'s Avatar
Member: 329483
Sonork: 100
Thanks Meter: 443
any solution for this problem till now ?!!!!!!!!!!!!!!
Old 09-29-2014, 20:10   #44 (permalink)
Member: 2242386
Thanks Meter: 7
Downgrade ;;iPhone4 - No Wifi- 7.1.2 Can not be activated with iTunes
How To Downgrade From iOS 7 to iOS 5.1.1 With No SHSH Blobs! - YouTube
Old 10-02-2014, 09:47   #45 (permalink)
Member: 1834175
Thanks Meter: 51
Smile
Originally Posted by jamesjerss View Post
THIS ISSUES HAD BEEN SOLVED :-)
AVOID TO TRY ABOVE SOLUTION
THE PROBLEM RETURNED TO WIFI IC
YOU NEED TO RUN YOUR DEVICE WITH THIS PROBLEM MAKE DOWNGRADE THEN ACTIVE IT BY Itunes APP :-)
TESTED BY ME
BEST REGARD . Eng.SALMAN FARAJ
https://www.facebook.com/The.Engineer.For.Communication
The Following User Says Thank You to sonsonsy For This Useful Post:
Page generated in 0.23890 seconds with 9 queries
