09-20-2014, 04:16 | #32 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Manila Phulippines
Member: 1246625 Status: Offline Thanks Meter: 21 | I got the same problem after restored to ios 7.1.2 cannot activate and error 0XE800004 occured. There was no wifi to activate via wifi. The satus of my iphone before was disabled. Any help please... br |
09-21-2014, 20:43 | #33 (permalink) |
Freak Poster Join Date: Feb 2011 Location: bahrain
Member: 1520821 Status: Offline Sonork: 100.1641523 Thanks Meter: 40 | me face the same prblm 2 days before what i do it reheat the wifi ic and suddenly connect with itunes my luck its come okk....u can try this method |
09-22-2014, 02:22 | #35 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2242386 Status: Offline Thanks Meter: 7 | Well! I think we four or 3 people who have this problem, I think should use an older Version of iTunes or using a Macintosh system. so my friends don't waste your time with hardware problems... we have something in Commun and is we have the problem of "No Wifi" and "0XE800004" so I will try some of my sollutions. Same Problem for other people in the forum sorry I can't put links i'm new |
09-22-2014, 04:35 | #36 (permalink) |
Junior Member Join Date: Feb 2005 Age: 46
Member: 112760 Status: Offline Thanks Meter: 1 | My version of iTunes is up to date and my S.O. is Windows 7 Ultimate SP1 is also updated. This error comes from iOS 7.1.2 if you downgrade to iOS 6.1.3 this problem with activation disappears, but the problem with the wifi connection persists. iOS 7.1.2 modifies something in the iPhone 4 that causes this error. |
09-22-2014, 05:38 | #37 (permalink) | |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | Quote:
Thread moved to hw section | |
09-22-2014, 07:24 | #38 (permalink) | |
Junior Member Join Date: May 2014
Member: 2193217 Status: Offline Thanks Meter: 0 | Quote:
this is a software problem, because I downgraded to 6.1.3 & I could active it through itunes who has SHSH,able to downgrade Apple stop's active these iphone with wifi broblem for some reasons | |
09-23-2014, 15:59 | #40 (permalink) | |
So when you install ios 7 you can activate your phone ? Sent from my iPhone using Tapatalk | |
09-23-2014, 19:28 | #41 (permalink) | |
I tried 2-3 iphone 4 (no WIFI) Apple doesn't active these phones anymore on iOS7 but if you saved SHSH,you can downgrade easy & able to active it via itunes even you didn't have SHSH ,you can downgrade but get tethered jailbreak so 3 options for who has iphone 4 no wifi 1- downgrade to ios 6.1.3 if you have SHSH with signal 2- hacktive ios 7 and use it like ipod, no signal 3- if you didn't save SHSH,downgrade it to ios 6.1.3 get signal but (tethered jailbreak) | |
09-29-2014, 20:10 | #44 (permalink) |
Member: 2242386 Status: Offline Thanks Meter: 7 | Downgrade ;;iPhone4 - No Wifi- 7.1.2 Can not be activated with iTunes How To Downgrade From iOS 7 to iOS 5.1.1 With No SHSH Blobs! - YouTube |
10-02-2014, 09:47 | #45 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Born in Syria,Live In Turkey
Member: 1834175 Status: Offline Thanks Meter: 51 | THIS ISSUES HAD BEEN SOLVED :-) AVOID TO TRY ABOVE SOLUTION THE PROBLEM RETURNED TO WIFI IC YOU NEED TO RUN YOUR DEVICE WITH THIS PROBLEM MAKE DOWNGRADE THEN ACTIVE IT BY Itunes APP :-) TESTED BY ME BEST REGARD . Eng.SALMAN FARAJ https://www.facebook.com/The.Engineer.For.Communication |
The Following User Says Thank You to sonsonsy For This Useful Post: |
