02-24-2014, 19:59 | #1 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 420820 Status: Offline Thanks Meter: 71 | iPhone 4 Changed screen now showing iphones is disabled - need to reset wait time CANT DO RESTORE as the customer needs the data on the phone and they don't have a backup at all or iCloud switched on!!! The phone has data turned off as customer just came back from holiday and when i connect to iTunes it isn't working, they don't have their own iTunes so cant reset by connecting to a previously synced computer. How can i correct time or reset iPhone is disabled, i know the pass code so just need to reset the time. Thanks in advance for any help Last edited by roxrox; 02-24-2014 at 20:08. |
02-26-2014, 09:05 | #2 (permalink) |
Moderator Join Date: Feb 2006 Location: Bangladesh & Bahrain
Member: 233205 Status: Offline Thanks Meter: 5,014 | 2way- 1. you need to correct your phone time and date (put any 3g supported sim or open wifi from ios7 on screen down menu so it will auto connect already known wifi so internet connection auto corret date and time). when time and date will be correct you can see regular disable minute. 2. Use Geeko Toolkit. |
The Following 2 Users Say Thank You to tkowsar For This Useful Post: |
02-27-2014, 12:14 | #6 (permalink) |
Member: 420820 Status: Offline Thanks Meter: 71 | issue is not screen issue, i know this, what i'm saying issue is, when i removed battery the date and time got reset to 1970 hence why minutes to wait went from 50 minutes to 22 million minutes. I can't put in data sim as customer turned off data and no way to turn on. Not sure about the wifi though, will check with customer if they hooked up with their wifi in the past and see if that helps, thanks If not will Gecko toolkit work on iOS7? Thanks |
02-27-2014, 12:26 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | try this try connecting phone to itunes many times and check if your iphone date has been fixed normalyy without disable iphone itunes sync time between device and pc |
02-27-2014, 14:22 | #8 (permalink) |
Member: 420820 Status: Offline Thanks Meter: 71 | Tried this many times my friend but iTunes keeps saying something like to continue please confirm on your device, but obviously cant do that because cant get acces to the phone because is disabled |
03-01-2014, 18:39 | #9 (permalink) |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | ****ing awnsome today happend to me ! how to recover any data or fix time ? or any software if i put device in dfu to copy data or something |
03-01-2014, 18:54 | #10 (permalink) |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | hi i have been able to mount iphone memory in dfu mode via exploits and connect via ftp but where what folders are photo stored???? |
07-19-2014, 16:25 | #11 (permalink) | |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | weird , today happend Again to me with Iphone 5s ,, and i Followed this withoug any succses Quote:
