Old 12-15-2010, 06:58   #16 (permalink)
Crazy Poster
Member: 1467882
Thanks Meter: 2
GSMunlockvilla did u get it fixed? what baseband u at?
Old 12-15-2010, 07:04   #17 (permalink)
Crazy Poster
Member: 1467882
Thanks Meter: 2
Originally Posted by algerienbox View Post
other link.................
can this use for 4.2.1 or is it for 4.1?
Old 12-15-2010, 08:45   #18 (permalink)
GSMunlockvilla's Avatar
Member: 1022742
Thanks Meter: 187
@Ruttus no my problem is nt yet fixed i m searching for 4.2.1 custom file i dnt think its exist
let see
@algerienbox thanx for clearing about dfu mode.but problem is still same need iphone 4 custom file now if u can help.
Regards
Old 12-15-2010, 10:24   #19 (permalink)
Member: 621698
Thanks Meter: 405
Originally Posted by ..::Mobile Smoker::.. View Post
Replace Host File With It
C:\WINDOWS\system32\drivers\etc
Mobile smoker, I 'm thankful that you posted this solutions and it work for my iphone 4 that get 1013. using windows xp only
GSMunlockvilla try it and will work for sure! First do DFU mode then flash it
I used the same computer that had me erro1013 and changed " HOSTS " like mobile smoker's posted!
Old 12-15-2010, 12:11   #20 (permalink)
Member: 31246
Thanks Meter: 54
what was your trouble ? is it iphone 4 and can u unlocked it now ? with wich version did u flashed it ?
Old 12-16-2010, 14:00   #21 (permalink)
Crazy Poster
Member: 1467882
Thanks Meter: 2
let see
Regards
thin i found one try http://dlf.transfer.ro/transfer_ro-1...5c74f225f6.zip
also how did u upgrade your base band to 6.15?
Old 12-16-2010, 14:06   #22 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,126
iphone 4 cannot update with ipad baseband....
Old 12-17-2010, 18:05   #23 (permalink)
Member: 1065550
Sonork: gsmstar
Thanks Meter: 12
Iphone error 1013
hello, I have the same problem with my iphone 4 while restoring it gives the error 1013. I changed the host file, reinstalled itunes, checked with DFU mode. but same problem.
What can be the solution?
Thanks,
Old 12-17-2010, 22:10   #24 (permalink)
Member: 157340
Thanks Meter: 3
final solution iphone 4.2.1
1. Connect your phone with PC and switch off...
2. Open redsnow and choose Original firmware...
3. If you have newboot just press " yes"
4. now click " Next"
5. Choose " Just Enter pwned DFU mode right now"
6 now click " Next" again "Next" and follow the screen....
After that open itunes and press " Shift + Restore" and choose custom firmware 4.2.1...
it will finish very quickly ......
Once you update you firmware....follow this...
5. Choose Only " Install Cydia"
6. now click " Next" again "Next" and follow the screen....
If you r getting White Cydia Icon just switch of your phone and open redsnow choose Stock firmware 4.2.1 and choose the option "Just boot tethered right now" and click "next" again "next" then follow the screen...then you will see the cydia...
Finally you can see your phones is with your old Baseband. now just you can install the ultrasnow 1.2 from Cydia adding this link "ultrasn0w.com"
and every time when the iphone stuck on reboot use redsnow 6b5 or 6b6 with oly checking on "Just boot tethered right now".
Old 12-18-2010, 09:34   #25 (permalink)
..::Mobile Smoker::..'s Avatar
Member: 170380
Sonork: 100.1577994
Thanks Meter: 3,022
let see
Regards
No Need Custom Firmware Just Replace Host File
Or Remove 74.208.10.249 gs.apple.com From Your Host File
& Reboot Pc Working 10000%
Old 02-05-2011, 18:47   #26 (permalink)
Member: 1510030
THANKYOU SOOO MUCH i was having the same error 1013 and 1011 i came across this forum and gave it a shot soo glad i did this saved my iPhone ^_^
Old 02-05-2011, 20:11   #27 (permalink)
Member: 1276595
Thanks Meter: 4
Hello to all iphone experts
i have iphone-4 os 4.2.1 after patch for apps fone all done i just reboot my phone fone stucked.i did boot thetreat same i try to restore it with same os 4.2.1 getting error 1013.then i change to other two pc now getting error 10.even i try with dfu mode same result with recovery mode same result.fone was working before its not factory unlocked fone jst wana use it as ipod cos not unlocked.
Ur quick reply must be appreciated.
problime solved just change hosts and try with coustom firmwear
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.33267 seconds with 10 queries
