-   iPhone 4 / iPhone 4S (http://forum.gsmhosting.com/vbb/f456/)
-   -   Iphone 4 crazy problem need help (http://forum.gsmhosting.com/vbb/f456/iphone-4-crazy-problem-need-help-1163471/)
GSMunlockvilla 12-14-2010 07:54
Hello to all iphone experts
i have iphone-4 os 4.2.1 after patch for apps fone all done i just reboot my phone fone stucked.i did boot thetreat same i try to restore it with same os 4.2.1 getting error 1013.then i change to other two pc now getting error 10.even i try with dfu mode same result with recovery mode same result.fone was working before its not factory unlocked fone jst wana use it as ipod cos not unlocked.
Ur quick reply must be appreciated.
Mr.3. 12-14-2010 08:06
did u remove saurik server address from host file?
GSMunlockvilla 12-14-2010 08:18
Do u have adress which i need to remove???
..::Mobile Smoker::.. 12-14-2010 09:30
1 Attachment(s)
Replace Host File With It
C:\WINDOWS\system32\drivers\etc
..::Mobile Smoker::.. 12-14-2010 09:35
But After Complete Restore You Will Not Be To Unlock It With Ultrasn0w
GSMunlockvilla 12-14-2010 09:37
i dnt want to unlock my phone just want it back to its orginal condition let me try and give u result
Regards
xerraco 12-14-2010 09:53
iPhone 4 4.2.1 if JD is tethered, need to use redsn0w_win_0.9.6b6 check on "Just boot tethered right now".
GSMunlockvilla 12-14-2010 10:42
@..::Mobile Smoker::.. now getting 3194 error.
@xerraco not worked?:(
Regards
algerienbox 12-14-2010 12:33
anter your phone to mode DFU with redsnow
open itune and restore your phone with costum firmware 4.2.1
mohamed75 12-14-2010 12:47
i have the same problem and after using the attached hosts file all is ok now
GSMunlockvilla 12-14-2010 14:25
@algerienbox i m doing with dfu mode but yes from where i can find custom file??
@mohamed75 i did try but same after change the host file.Tell me did u tried with custom file???
algerienbox 12-14-2010 14:32
there is a diffrent between DFU mode of redsnow and DFU mode manuel
redsnow DFU = only for costum firmware
manuel DFU = for officiel firmware
for the costum firmware is already posted in forum .
try to use this one
http://www.***********.com/191282582...cktivated.ipsw
if dont work try with 4.2.1 costum
algerienbox 12-14-2010 14:36
1 Attachment(s)
other link.................
mymiela0419 12-15-2010 04:32
Hello GSMunlockvilla, did you fix your iphone 4 error 1013?
If you do please kindly share your thoughts because I do have the same problem. I have iphone 4 with passcode. I did flash it with orginal iphone 4 IPSW 4.2.1 then it get stuck in recovery mode only and gave me 1013 error...
I think this iphone 4 ( OLD OWNER ) has 4.2.1 version then jailbrake for customer firmware, 4.2.1 then my customer found it somewhere. and he want me to remove passcode so I have to restore i( the only way to remove passcode from iphone 4 ) then this ERROR 1013 come out!
Any solutions or I'm F*c*k*d up! :( any suggestion will help thank you
rajesh_ch 12-15-2010 05:23
thanks for help sir ur file is working 100% ok
thanks once again
wbr.
rajesh ch.
Page generated in 0.27119 seconds with 5 queries
