GSMunlockvilla did u get it fixed? what baseband u at? |
@Ruttus no my problem is nt yet fixed i m searching for 4.2.1 custom file i dnt think its exist;) let see @algerienbox thanx for clearing about dfu mode.but problem is still same need iphone 4 custom file now if u can help. Regards |
GSMunlockvilla try it and will work for sure! First do DFU mode then flash it :) I used the same computer that had me erro1013 and changed " HOSTS " like mobile smoker's posted! :) |
what was your trouble ? is it iphone 4 and can u unlocked it now ? with wich version did u flashed it ? Quote:
also how did u upgrade your base band to 6.15? |
Iphone error 1013 hello, I have the same problem with my iphone 4 while restoring it gives the error 1013. I changed the host file, reinstalled itunes, checked with DFU mode. but same problem. What can be the solution? Thanks, |
final solution iphone 4.2.1 1. Connect your phone with PC and switch off... 2. Open redsnow and choose Original firmware... 3. If you have newboot just press " yes" 4. now click " Next" 5. Choose " Just Enter pwned DFU mode right now" 6 now click " Next" again "Next" and follow the screen.... After that open itunes and press " Shift + Restore" and choose custom firmware 4.2.1... it will finish very quickly ...... Once you update you firmware....follow this... 1. Connect your phone with PC and switch off... 2. Open redsnow and choose Original firmware... 3. If you have newboot just press " yes" 4. now click " Next" 5. Choose Only " Install Cydia" 6. now click " Next" again "Next" and follow the screen.... If you r getting White Cydia Icon just switch of your phone and open redsnow choose Stock firmware 4.2.1 and choose the option "Just boot tethered right now" and click "next" again "next" then follow the screen...then you will see the cydia... Finally you can see your phones is with your old Baseband. now just you can install the ultrasnow 1.2 from Cydia adding this link "ultrasn0w.com" and every time when the iphone stuck on reboot use redsnow 6b5 or 6b6 with oly checking on "Just boot tethered right now". |
Or Remove 74.208.10.249 gs.apple.com From Your Host File & Reboot Pc Working 10000% |
THANKYOU SOOO MUCH i was having the same error 1013 and 1011 i came across this forum and gave it a shot soo glad i did this saved my iPhone ^_^ |
