Old 12-14-2010, 08:54   #1 (permalink)
GSMunlockvilla's Avatar
Member: 1022742
Thanks Meter: 187
Iphone 4 crazy problem need help
Hello to all iphone experts
i have iphone-4 os 4.2.1 after patch for apps fone all done i just reboot my phone fone stucked.i did boot thetreat same i try to restore it with same os 4.2.1 getting error 1013.then i change to other two pc now getting error 10.even i try with dfu mode same result with recovery mode same result.fone was working before its not factory unlocked fone jst wana use it as ipod cos not unlocked.
Ur quick reply must be appreciated.
Old 12-14-2010, 09:06   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,126
did u remove saurik server address from host file?
Old 12-14-2010, 09:18   #3 (permalink)
Member: 1022742
Thanks Meter: 187
Do u have adress which i need to remove???
Old 12-14-2010, 10:30   #4 (permalink)
..::Mobile Smoker::..'s Avatar
Member: 170380
Sonork: 100.1577994
Thanks Meter: 3,022
Replace Host File With It
C:\WINDOWS\system32\drivers\etc
File Type: zip hosts.zip (518 Bytes, 512 views)
The Following 7 Users Say Thank You to ..::Mobile Smoker::.. For This Useful Post:
Old 12-14-2010, 10:35   #5 (permalink)
Member: 170380
Sonork: 100.1577994
Thanks Meter: 3,022
But After Complete Restore You Will Not Be To Unlock It With Ultrasn0w
The Following User Says Thank You to ..::Mobile Smoker::.. For This Useful Post:
Old 12-14-2010, 10:37   #6 (permalink)
Member: 1022742
Thanks Meter: 187
i dnt want to unlock my phone just want it back to its orginal condition let me try and give u result
Regards
Old 12-14-2010, 10:53   #7 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
iPhone 4 4.2.1 if JD is tethered, need to use redsn0w_win_0.9.6b6 check on "Just boot tethered right now".
Old 12-14-2010, 11:42   #8 (permalink)
Member: 1022742
Thanks Meter: 187
@..::Mobile Smoker::.. now getting 3194 error.
@xerraco not worked?
Regards
Old 12-14-2010, 13:33   #9 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 561
anter your phone to mode DFU with redsnow
open itune and restore your phone with costum firmware 4.2.1
Old 12-14-2010, 13:47   #10 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Thanks Meter: 186
i have the same problem and after using the attached hosts file all is ok now
Old 12-14-2010, 15:25   #11 (permalink)
Member: 1022742
Thanks Meter: 187
@algerienbox i m doing with dfu mode but yes from where i can find custom file??
@mohamed75 i did try but same after change the host file.Tell me did u tried with custom file???
Old 12-14-2010, 15:32   #12 (permalink)
Member: 591880
Thanks Meter: 561
there is a diffrent between DFU mode of redsnow and DFU mode manuel
redsnow DFU = only for costum firmware
manuel DFU = for officiel firmware
for the costum firmware is already posted in forum .
try to use this one
http://www.***********.com/191282582...cktivated.ipsw
if dont work try with 4.2.1 costum
The Following User Says Thank You to algerienbox For This Useful Post:
Old 12-14-2010, 15:36   #13 (permalink)
Member: 591880
Thanks Meter: 561
other link.................
File Type: txt Nouveau Document texte.txt (65 Bytes, 129 views)
Old 12-15-2010, 05:32   #14 (permalink)
Member: 621698
Thanks Meter: 405
Hello GSMunlockvilla, did you fix your iphone 4 error 1013?
If you do please kindly share your thoughts because I do have the same problem. I have iphone 4 with passcode. I did flash it with orginal iphone 4 IPSW 4.2.1 then it get stuck in recovery mode only and gave me 1013 error...
I think this iphone 4 ( OLD OWNER ) has 4.2.1 version then jailbrake for customer firmware, 4.2.1 then my customer found it somewhere. and he want me to remove passcode so I have to restore i( the only way to remove passcode from iphone 4 ) then this ERROR 1013 come out!
Any solutions or I'm F*c*k*d up! any suggestion will help thank you
Old 12-15-2010, 06:23   #15 (permalink)
rajesh_ch's Avatar
Member: 618404
Thanks Meter: 311
thanks for help sir ur file is working 100% ok
thanks once again
wbr.
rajesh ch.
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.26334 seconds with 10 queries
