09-25-2014, 18:43 | #63 (permalink) |
No Life Poster Join Date: Sep 2008 Location: in your hart Age: 40
Member: 864102 Status: Offline Sonork: 100.1617637 Thanks Meter: 146 | dear frends iphone 4 eroor 3194 this set is dubai dubai means manufeacured by dubai try to dungrade by redsnow 15b3 restore farmwere 5.0.1 after restore network is ok 10000% done testede by me |
09-26-2014, 08:23 | #66 (permalink) |
Super Moderator Join Date: May 1999 Location: Wien/Austria Age: 48
Member: 16 Status: Offline Sonork: 100.1652085 GSMWorld Thanks Meter: 1,743 | Hello Guys These steps will get you started, and there are additional troubleshooting steps if needed in the article: Important: If you see one of these messages and need help updating or restoring your iOS device, Install the latest version of iTunes and try to update or restore again. After that, follow these steps if you need more help. Check your "hosts" file After you've updated iTunes to the latest version, you can check the hosts file to be sure your computer can contact the update server. Use the numbered steps below if you’re on a Mac. If you’re using a Windows computer, follow steps in this Microsoft support article, noting that resetting the hosts file will affect software services that rely on hosts file redirects. If you're using Windows on a business computer, consult your IT department to be sure applications will still work correctly after resetting the hosts file. In the Finder, choose Applications > Utilities. Open Terminal. Enter this command and then press Return: sudo nano /private/etc/hosts Enter the password you use to sign in to your computer and press Return. You won't see text appear in the Terminal window when you enter the password. Make sure you use a nonblank administrator password. Terminal will display the hosts file. Navigate using the arrow keys and look for an entry containing “gs.apple.com”. Add the # symbol and a space ("# ") to the beginning of the gs.apple.com entry. TS4451_02--hosts_file-001-mul.png Press Control-O to save the file. Then, press Enter when prompted for the filename and Control-X to exit the editor. Restart your computer. Try to update or restore your iOS device again.
__________________ Wbr GSMWorld |
10-03-2014, 04:31 | #68 (permalink) |
Insane Poster Join Date: May 2013 Location: Philippines
Member: 1946715 Status: Offline Sonork: idonthave Thanks Meter: 6 | Refurbish Iphone 4 can only update firmware via Redsn0w!, done by me get a latest redsn0w ifaith do not stitch blob just normal IPSW, shsh and ipsw are in the same folder open redsn0w extra , more, restore do not update baseband, just click yes ,, DFU your phone done!!! |
10-31-2014, 05:09 | #73 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Home Sweet Home
Member: 1322701 Status: Offline Thanks Meter: 127 | Quote:
when i check that modem firmware and imei its all gone(empty) its baseband related issues right? what do i do to fix them please i have been searching for a fix for months now Thanks in advance | |
