12-19-2012, 05:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Iphone 4 error 3194 when restore 6.0.1 I have Iphone 4 desactivated with passcode and can't connect to itune I use Gecko to get code code readed ok but can't put it because emergency call only with Gecko I press bypass but not success and now phone on recovr mode Now I can connect it to itune to restore but get error 3194 Please help Thanks in advance Model: IPHONE 4 16GB BLACK Version: 6.0.1 Imei: 012430001128557 Serial: 700346L0A4S Country code: GB MAC: 18E7F4F29426 Activated: YES (25/11/12) Carrier: O2 - United Kingdom GBR Phone: UNLOCKED (PLEASE CONNECT TO ITUNES) T |
12-19-2012, 05:56 | #4 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
use latest itunes 11.0.1 to restore it like usual... br | |
12-19-2012, 06:01 | #5 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | C:\WINDOWS\system32\drivers\etc and edit this # Copyright (c) 1993-1999 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP ad******* to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host 127.0.0.1 localhost then restore again |
12-19-2012, 08:26 | #8 (permalink) |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Hi, all after instal latest itune recovry mode is gone Now phone return normal and can't connect to itune need passcode how to put code if phone in emergence call please help |
12-19-2012, 08:31 | #9 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
Best Regards, azam | |
12-19-2012, 08:51 | #14 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dhaka, Bangladesh.
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Only host file can solve error 3194 problem. search before post on forum. If you using trinyUmbrella, then modify the host. |
