07-09-2013, 13:53 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: Kazakhstan Age: 40
Member: 66701 Status: Offline Thanks Meter: 39 | Iphone 4 error on activating Your iphone could not be activated bacause the activation Server is temporarily unavailable. ....... MEI : 012746003620170 UNLOCK CODE : IMEI: 012746003620170 Serial Number: 7R118KRDDZZ Part Description: IPHONE 4 16GB WHITE Product Version: Coverage Status: Out of Warranty Coverage End Date: First Unbrick Date: Last Unbrick Date: Next Tether Activation Policy Description: Unlock. Lock Status: Unlocked Maybe modem is replaced? And no any variant to activate it? |
07-12-2013, 10:02 | #3 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: I T A L I A
Member: 1676058 Status: Offline Thanks Meter: 48 | Quote:
many time it show u r device is not b actiated but try again after some then device is activate u must b try after some time hope will b fine | |
07-12-2013, 14:22 | #4 (permalink) |
No Life Poster Join Date: Apr 2012 Location: < Man is stronger than stone.>
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | If you didnt make a clean restore, if is jailbroken, than can be problem during activation... Otherwise, you can try throught wifi, no itunes, probably you did that. worst thing can be, barred by operator, hopefully not.. BR |
07-12-2013, 14:41 | #6 (permalink) |
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | did you make factory by your own, or you received factory unlocked already.. Cause must know which operator was locked, to know if is not barred... First musk ask, does it shows emergency calls..if it doesnt shows HARDWARE problem.. 1. Try on another PC, to activate.....Itunes on it, Correct time and date PC.. 2.Check hardware any antena or smth are they properly in place.. 3.Make jailbreake with redsnow 0.9.15b3, it will be tethered....or any version with SSH blobs, that can be untethered..5.0.1, 5.1.1 any other ios 6.X. reason.. must check all the details on iphone on settings/about? modem firware, imei, all of them..are they displayed.. Last edited by cobra iphoni; 07-12-2013 at 14:47. Reason: forget smth to mention>>> |
07-12-2013, 15:16 | #7 (permalink) |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | issues in Pakistan - Apple Activation , Restoring , Updates , Appstore ,iCloud https://forum.gsmhosting.com/vbb/9561049-post.html ------------------------------------- Regards, GSM-DOCTOR |
The Following User Says Thank You to GSM-DOCTOR For This Useful Post: |
