Old 02-22-2014, 02:08   #16 (permalink)
Member: 556768
Thanks Meter: 157
How about disabled iphone?will it also work?
Old 02-22-2014, 14:06   #17 (permalink)
Member: 1099349
Thanks Meter: 105
no,, to remove iPhone disabled you have to delete or edit a file in \mnt1\System\Library\Preferences called com.apple.springboard.plist.
here are stored your wrong tries count,, so when u delete it, iPhone is disabled is gone.
you just need ssh_rd_rev04b.jar file,, google for it,, and WinSCP,, google for it too.. and google for tutorial.
The Following User Says Thank You to decco For This Useful Post:
Old 02-22-2014, 17:20   #18 (permalink)
Member: 2074110
Sonork: 92458589.7230895
Thanks Meter: 10
no wont work because disabled you have to deleate what he said up there
sag
Old 02-22-2014, 20:34   #19 (permalink)
Member: 1974488
Thanks Meter: 5
is there any vedio explain that please!
Old 02-23-2014, 09:53   #20 (permalink)
Member: 1099349
Thanks Meter: 105
just wait a little bit, i will post a tutorial.
Old 02-23-2014, 19:38   #21 (permalink)
Member: 1817422
Sonork: 100.1617675
Thanks Meter: 24
I had hard time to manage this to work, but now its tested on two iPhone 4 models 7.0 and 7.0.4 iOS versions.
ONLY iPhone 4 (IPHONE3,1) revision is supported !!!
so.. lets get started.
Download this .rar Zippyshare.com and extract it to any folder you want, in my case its c:/A folder. you will need winrar to extract. WinRAR archiver
Download iphone firmware to the same folder. http://appldnld.apple.com/iPhone4/04...5_Restore.ipsw
1. Lets Go in to DFU mode by doing as showed here How To Put Your iPhone Into DFU Mode
4. Launch "Gecko_iPhone_Toolkit.exe: From Folder, Chose iPhone 4 (GSM) and press BOOT, than OK, than choose iphone firmware we just downloaded (strictly it should be in the same directory as every other files)
NOTHING SHOULD HAPPEN!
5. Leave gecko software running and launch RUN.bat from same folder and wait until redsn0w finish his job. when it tells you that it is DONE ! and start looking at your iphone screen.
6. Once in iPhone screen you will see a big white OK, Quit Redsnow, and go back to GECKO, press LAUNCH button and vait about 30 or 40min untill software Bruteforces your password.
iGnore any errors you see on screen, ignore that Gecko tool is frozen, just leave everything and depending on what passcode it is it will take some time, for example 0011 code takes about 5 to 10 seconds to break, 5555 passcode needs about 30 minutes, so 9999 can take more than one hour i think.
When software founds your password, it will prompts text with your passcode in Gecko tool as usually on iOS 6. so just be patient.
You can donate if you made some money from this tutorial.
NO QUESTIONS ABOUT 4s, 5, 5s, 5c etc PLEASE. its not supported!
GOOD LUCK!
Report Post Reply With Quote
Old 02-25-2014, 15:11   #22 (permalink)
Member: 1974488
Thanks Meter: 5
with redsn0w with witch frameware shuld i use ?
Old 02-25-2014, 15:42   #23 (permalink)
Member: 2066290
Thanks Meter: 11
which firmware should i download ?? ur link or just the same device version??
Old 02-25-2014, 21:20   #24 (permalink)
Member: 946836
Thanks Meter: 17
nice work,,,,
done 3 pcs iphone 4gsm,,,,
thanks dude,,,
Old 02-26-2014, 12:43   #25 (permalink)
Member: 1974488
Thanks Meter: 5
i use redsn0w with the same frimware i downloaded ? http://appldnld.apple.com/iPhone4/04...5_Restore.ipsw
Old 02-26-2014, 13:29   #26 (permalink)
Member: 1974488
Thanks Meter: 5
when i use redsn0w with the same ipsw ? or how ?
Old 02-27-2014, 12:35   #27 (permalink)
Member: 1099349
Thanks Meter: 105
just tell me exactly what is wrong for you? maybe i can help...
Old 02-27-2014, 12:36   #28 (permalink)
Member: 1099349
Thanks Meter: 105
Originally Posted by manessmann View Post
nice work,,,,
thanks dude,,,
at least someone tested it... NICE,,, soon will post easy tutorial for HOW TO REMOVE iPHONE IS DISABLED on ios 7.x.x iphone 4 (3,1 rev) only..
Old 02-27-2014, 12:46   #29 (permalink)
Cheater -Don't Deal with him-
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 520
Worked on iphone 4g 16gb GSM just I tested on my iphone
Old 02-27-2014, 14:49   #30 (permalink)
Member: 1974488
Thanks Meter: 5
after black screan what i have to do and how to insert passcode or it cracked automatic ?
Page generated in 0.23087 seconds with 8 queries
