Old 09-18-2014, 15:17   #181 (permalink)
osfloca's Avatar
Member: 2109406
Sonork: 100.1657612
Thanks Meter: 37
Anyone know how to delete icloud account ios 8 after remove pass?
Old 09-19-2014, 20:12   #182 (permalink)
Member: 1769145
i'll try it, thanks a lot
Old 10-15-2014, 14:26   #183 (permalink)
Cheater -Don't Deal with him-
Member: 1102864
Sonork: 100.1681662
Thanks Meter: 854
Does anyone has kernel.patched and ramdisk for iPhone 4 8 GB ?
Old 12-06-2014, 05:06   #184 (permalink)
Member: 1846961
Thanks Meter: 3
Worked on iphone 4 iso 7.1.2 (11D257) PASSCODE :8787 in 20 minutes, thanks cracker
Old 12-06-2014, 16:49   #185 (permalink)
Member: 1999993
Thank you for the info and your help. You made an excellent job. Now i have a question:
I have a problem with an disabled mode iphone 4 and followed all of your instruction. But at the end i can't go to the directory: mnt1/System/Library/Preferences/com.apple.springboard.plist because i didn't found the subdirectory /Preferences/ and so one.
Could you please help me what to do to find it?
I searched with "find files" option on the WinSCP program and not found again.
Waiting for your kindly response.
Thank you again
Old 12-06-2014, 23:44   #186 (permalink)
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 520
Thank you again
http://forum.gsmhosting.com/vbb/f456...l-ios-1873929/
br
Old 12-11-2014, 07:02   #187 (permalink)
Member: 2308645
Updated my iphone 4 rev 3,1 to ios 8.0 and added passcode to test... read without any problems....
Old 12-11-2014, 19:39   #188 (permalink)
Member: 2089356
Thanks Meter: 520
I don't know ios 8 for ip4?
Can you post more info i want more info
The Following User Says Thank You to BesfortShalaTec For This Useful Post:
Old 12-28-2014, 10:00   #189 (permalink)
gwlime's Avatar
Member: 1493085
Sonork: n/a
Thanks Meter: 92
iPhone 3.1 IOS 8 fake
The Following User Says Thank You to gwlime For This Useful Post:
Old 04-30-2015, 02:17   #190 (permalink)
pldtn's Avatar
Member: 124221
Thanks Meter: 13
Originally Posted by decco View Post
I had hard time to manage this to work, but now its tested on two iPhone 4 models 7.0 and 7.0.4 iOS versions.
ONLY iPhone 4 (IPHONE3,1) revision is supported !!!
so.. lets get started.
Download this .rar Zippyshare.com and extract it to any folder you want, in my case its c:/A folder. you will need winrar to extract. WinRAR archiver
Download iphone firmware to the same folder. http://appldnld.apple.com/iPhone4/04...5_Restore.ipsw
1. Lets Go in to DFU mode by doing as showed here How To Put Your iPhone Into DFU Mode
4. Launch "Gecko_iPhone_Toolkit.exe: From Folder, Chose iPhone 4 (GSM) and press BOOT, than OK, than choose iphone firmware we just downloaded (strictly it should be in the same directory as every other files)
NOTHING SHOULD HAPPEN!
5. Leave gecko software running and launch RUN.bat from same folder and wait until redsn0w finish his job. when it tells you that it is DONE ! and start looking at your iphone screen.
6. Once in iPhone screen you will see a big white OK, Quit Redsnow, and go back to GECKO, press LAUNCH button and vait about 30 or 40min untill software Bruteforces your password.
iGnore any errors you see on screen, ignore that Gecko tool is frozen, just leave everything and depending on what passcode it is it will take some time, for example 0011 code takes about 5 to 10 seconds to break, 5555 passcode needs about 30 minutes, so 9999 can take more than one hour i think.
When software founds your password, it will prompts text with your passcode in Gecko tool as usually on iOS 6. so just be patient.
You can donate if you made some money from this tutorial.
NO QUESTIONS ABOUT 4s, 5, 5s, 5c etc PLEASE. its not supported!
GOOD LUCK!
working for me thx u! But the problem is Cydia Installed and can't open SAFARI, MAIL and CYDIA, open it and close.... Please need FIX THIS!!!!
Old 05-08-2015, 17:14   #191 (permalink)
Member: 2244785
iphone 4
anybody can help with not charging iphone 4?or fake charging?
Old 06-04-2015, 02:43   #192 (permalink)
Member: 545520
Thanks Meter: 50
iphone 4 ios 7.1.2 read pass code ok by this tool.
Old 06-23-2015, 14:22   #193 (permalink)
Member: 2414679
Hey man,
Has the Rev A compatibility issue been solved? I can't get in to my iphone! I've run all sorts of combination tests that all result in the same issue...
FAILed to load Keybag...
Old 06-24-2015, 11:15   #194 (permalink)
Member: 2235709
Thanks Meter: 3
are you here? i can help you. do you visit forum after 5 hours?
Old 07-05-2015, 09:17   #195 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
Anyone have issue after open Gecko and choose boot .. after choose ipsw 501 its unspected parameter .. help
my pc is windows 7
java already instaled
helppp
Page generated in 0.20808 seconds with 8 queries
