Old 02-11-2014, 20:42   #1 (permalink)
Member: 1099349
Thanks Meter: 105
iPhone 4 iOS 7.x.x PassCode READ. WINDOWS ONLY.
I had hard time to manage this to work, but now its tested on two iPhone 4 models 7.0 and 7.0.4 iOS versions.
ONLY iPhone 4 (IPHONE3,1) revision is supported !!!
so.. lets get started.
Download this .rar Zippyshare.com and extract it to any folder you want, in my case its c:/A folder. you will need winrar to extract. WinRAR archiver
Download iphone firmware to the same folder. http://appldnld.apple.com/iPhone4/04...5_Restore.ipsw
1. Lets Go in to DFU mode by doing as showed here How To Put Your iPhone Into DFU Mode
4. Launch "Gecko_iPhone_Toolkit.exe: From Folder, Chose iPhone 4 (GSM) and press BOOT, than OK, than choose iphone firmware we just downloaded (strictly it should be in the same directory as every other files)
NOTHING SHOULD HAPPEN!
5. Leave gecko software running and launch RUN.bat from same folder and wait until redsn0w finish his job. when it tells you that it is DONE ! and start looking at your iphone screen.
6. Once in iPhone screen you will see a big white OK, Quit Redsnow, and go back to GECKO, press LAUNCH button and vait about 30 or 40min untill software Bruteforces your password.
iGnore any errors you see on screen, ignore that Gecko tool is frozen, just leave everything and depending on what passcode it is it will take some time, for example 0011 code takes about 5 to 10 seconds to break, 5555 passcode needs about 30 minutes, so 9999 can take more than one hour i think.
When software founds your password, it will prompts text with your passcode in Gecko tool as usually on iOS 6. so just be patient.
You can donate if you made some money from this tutorial.
NO QUESTIONS ABOUT 4s, 5, 5s, 5c etc PLEASE. its not supported!
GOOD LUCK!
The Following 16 Users Say Thank You to decco For This Useful Post:
Old 02-12-2014, 04:45   #2 (permalink)
Member: 1196054
Sonork: 31011983
Thanks Meter: 4
why not work for me? my iphone 4 ios 7.0.4
The Following User Says Thank You to nicola007 For This Useful Post:
Old 02-12-2014, 10:08   #3 (permalink)
Member: 1099349
Thanks Meter: 105
what is your iphone revision? where and what problem u get?
The Following User Says Thank You to decco For This Useful Post:
Old 02-12-2014, 10:26   #4 (permalink)
Member: 1099349
Thanks Meter: 105
please try and post result for me.
Old 02-12-2014, 10:48   #5 (permalink)
Member: 1110430
Thanks Meter: 104
GOOD LUCK!
Has anyone tried this method of breaking iphone4 password?
Let us hear or see the the result.
The Following 2 Users Say Thank You to Dzelailai For This Useful Post:
Old 02-12-2014, 11:51   #6 (permalink)
Member: 1099349
Thanks Meter: 105
i tried this method on two different iphone 4 phones with 7.0 and 7.0.4.
both working.
Old 02-12-2014, 15:09   #7 (permalink)
Member: 388862
Thanks Meter: 107
not work...............I test
Old 02-12-2014, 17:44   #8 (permalink)
Member: 1099349
Thanks Meter: 105
what iphone you have? what is iphone revision?
Old 02-13-2014, 00:38   #9 (permalink)
Member: 388862
Thanks Meter: 107
i test iphone 4 7.04
Old 02-13-2014, 14:37   #10 (permalink)
Member: 1099349
Thanks Meter: 105
it is iOS vcersion, not revision..
please look at this table. and check if your iphone version is compatible. compatible versions is marked in RED.
Old 02-21-2014, 11:45   #11 (permalink)
Member: 388862
Thanks Meter: 107
Device UDID : 75d0529eada0ff9d414bea4cc804dc186c808399
Keybag: SIGN check FAIL
Keybag UUID : 109b185b07e4405fbd84d976733e76a4
Saving C:\A\tools\bruteforce\75d0529eada0ff9d414bea4cc804 dc186c808399/aa15d28eb646ed8b.plist
passcodeKeyboardComplexity : {'rangeMinimum': 0, 'value': 0, 'rangeMaximum': 2}
Trying all 4-digits passcodes...
Old 02-21-2014, 18:53   #12 (permalink)
Member: 1099349
Thanks Meter: 105
as i said... in a first post.
"iGnore any errors you see on screen, ignore that Gecko tool is frozen, just leave everything and depending on what passcode it is it will take some time, for example 0011 code takes about 5 to 10 seconds to break, 5555 passcode needs about 30 minutes, so 9999 can take more than one hour i think.
When software founds your password, it will prompts text with your passcode in Gecko tool as usually on iOS 6. so just be patient."
does it shows many rows with same text now?
Old 02-21-2014, 19:15   #13 (permalink)
Member: 946836
Thanks Meter: 17
i will try in ipad2,,,,
just for research,,,,
Old 02-21-2014, 22:08   #14 (permalink)
Member: 1099349
Thanks Meter: 105
i dont think that iphone baseband will run on it,, but who knows im not a geek guy and dont really know how these things work
Old 02-22-2014, 01:30   #15 (permalink)
Member: 2074110
Sonork: 92458589.7230895
Thanks Meter: 10
wont work on ipad 2 sir! not going to be work good ok!!
sag
Page generated in 0.22670 seconds with 8 queries
