02-22-2014, 14:06 | #17 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Lithuania
Member: 1099349 Status: Offline Thanks Meter: 105 | no,, to remove iPhone disabled you have to delete or edit a file in \mnt1\System\Library\Preferences called com.apple.springboard.plist. here are stored your wrong tries count,, so when u delete it, iPhone is disabled is gone. you just need ssh_rd_rev04b.jar file,, google for it,, and WinSCP,, google for it too.. and google for tutorial. |
The Following User Says Thank You to decco For This Useful Post: |
02-23-2014, 19:38 | #21 (permalink) |
Banned Join Date: Sep 2012 Age: 45
Member: 1817422 Status: Offline Sonork: 100.1617675 Thanks Meter: 24 | I had hard time to manage this to work, but now its tested on two iPhone 4 models 7.0 and 7.0.4 iOS versions. ONLY iPhone 4 (IPHONE3,1) revision is supported !!! so.. lets get started. Download this .rar Zippyshare.com and extract it to any folder you want, in my case its c:/A folder. you will need winrar to extract. WinRAR archiver Download iphone firmware to the same folder. http://appldnld.apple.com/iPhone4/04...5_Restore.ipsw 1. Lets Go in to DFU mode by doing as showed here How To Put Your iPhone Into DFU Mode 4. Launch "Gecko_iPhone_Toolkit.exe: From Folder, Chose iPhone 4 (GSM) and press BOOT, than OK, than choose iphone firmware we just downloaded (strictly it should be in the same directory as every other files) NOTHING SHOULD HAPPEN! 5. Leave gecko software running and launch RUN.bat from same folder and wait until redsn0w finish his job. when it tells you that it is DONE ! and start looking at your iphone screen. 6. Once in iPhone screen you will see a big white OK, Quit Redsnow, and go back to GECKO, press LAUNCH button and vait about 30 or 40min untill software Bruteforces your password. iGnore any errors you see on screen, ignore that Gecko tool is frozen, just leave everything and depending on what passcode it is it will take some time, for example 0011 code takes about 5 to 10 seconds to break, 5555 passcode needs about 30 minutes, so 9999 can take more than one hour i think. When software founds your password, it will prompts text with your passcode in Gecko tool as usually on iOS 6. so just be patient. You can donate if you made some money from this tutorial. NO QUESTIONS ABOUT 4s, 5, 5s, 5c etc PLEASE. its not supported! GOOD LUCK! Report Post Reply With Quote |
02-26-2014, 12:43 | #25 (permalink) |
Insane Poster Join Date: Jul 2013 Location: Berlin
Member: 1974488 Status: Offline Thanks Meter: 5 | i use redsn0w with the same frimware i downloaded ? http://appldnld.apple.com/iPhone4/04...5_Restore.ipsw |
