Old 02-27-2014, 18:52   #31 (permalink)
Member: 1705517
Please Help my iPhone 4 32 GB (1332) 7.0.4
stops after click Launch on Gecko with these lines
Trying to mount data Partition
FAILed to load keybag
tested under xp, win7 and Win 8.1 always the same result !!
save me folks
Old 02-27-2014, 21:25   #32 (permalink)
Member: 1099349
Thanks Meter: 105
you are doing something wrong.. try to redownload a rar i posted in tutorial, and copy all files again.. maybe there is some fault with files or antivirus deleted some of them...
what is your iphone revision?
Old 02-27-2014, 21:27   #33 (permalink)
Member: 1099349
Thanks Meter: 105
Originally Posted by elhariri78 View Post
after black screan what i have to do and how to insert passcode or it cracked automatic ?
after what black screen? there should be no black screen during operation..
which step of tutorial is failing for you?
Old 03-18-2014, 23:58   #34 (permalink)
Member: 388862
Thanks Meter: 107
iphone 4 ios 7.1 not work ! Decco can help me ?Thank you!!!
Old 03-21-2014, 10:40   #35 (permalink)
Member: 468581
Thanks Meter: 4,294,967,293
iPhone 4 v.7.0.4 code in 2 min success Thank you very much
Device UDID : 35eba5bca0963e61cdcc78cc5243945949646226
Keybag: SIGN check FAIL
Keybag UUID : fc163f515ec3491ea4f274b50263fbdf
Saving G:\iPhone\Gecko iPhone Toolkit\A\tools\bruteforce\35eba5bca0963e61cdcc78c c5243945949646226/20ccc9d53b857202.plist
passcodeKeyboardComplexity : {'rangeMinimum': 0, 'value': 0, 'rangeMaximum': 2}
Trying all 4-digits passcodes...
BruteforceSystemKeyBag : 0:00:19.772000
{'passcode': '0106', 'passcodeKey': '145212b6447f3346eba0a0a79bf747b273f91a185dc52ff0b ccd071591ed1ff4'}
True
Keybag type : System keybag (0)
Keybag version : 4
Class WRAP Type Key
1 3 0 9eb246e8665cc1c642f2a37eef96216762107bef980e71da28 14d8e69d544ac7
2 3 1 03618a2e1054e75137948828db39b991db0463ce5030818a01 db9dac6d77eb00
3 3 0 4d8d07176b70db14a808e9f54187798f9d0f613bf2f38ced94 8824014447386c
5 3 0 f5e56cb4d07681b09932dde6d91a9f77b43c53c88e8c38cb9b 9e3236a4790f57
6 3 0 34c16a91bb12e58d9d82c07a65771fb9add04febecb382bc61 5811325b11efa6
7 3 0 2633f0322082e5d261a7210bdbe92040fa3669e157bc06e2cb d5fa6691c9479c
8 1 0 19a5b6163fecbbbd01a6703724636b1cc2416e6a7b3ec723ef 12f35d5c4d9037
9 3 0 090e3a9f8529f84c2eff82ea1b6ccb4cfa047a2282ffcb2e00 0134acd17b6fff
10 3 0 38cfac2de012fcc441e959ab8d2396226e8e2cbe9845c88185 714d430b2be4f9
11 1 0 d3228d8ff9a970580206f253fc2408ff6e81ba9ffdd800a88b 50c4b8215bf37d
Downloaded keychain database, use keychain_tool.py to decrypt secrets
The Following User Says Thank You to disskar2 For This Useful Post:
Old 03-21-2014, 10:44   #36 (permalink)
Member: 468581
True
Keybag version : 4
Class WRAP Type Key
Old 03-21-2014, 12:02   #37 (permalink)
Cheater -Don't Deal with him-
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 520
It works in Ios 7.1 tested by me
Sent from my GT-I8190N using Tapatalk
The Following 3 Users Say Thank You to BesfortShalaTec For This Useful Post:
Old 03-30-2014, 13:35   #38 (permalink)
Member: 1099349
Thanks Meter: 105
thank you for Letting us know !
Old 03-30-2014, 21:52   #39 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
great tool ..
but what if the IPhone was Disabled !!??
can this tool fix it too ??
Old 04-01-2014, 20:04   #40 (permalink)
Member: 1099349
Thanks Meter: 105
Originally Posted by MiRoOo View Post
great tool ..
you can fix iphone is disabled,,,
jsut ssh to your iphone via https://sites.google.com/site/msftgu..._rd_rev04b.jar
it only works with older tyva version 6,5 i think.. so you need to delete your java 7,x and install older one,, you can find it Old versions of Windows, Mac and Linux Software, Apps & Abandonware Games - Download at OldVersion.com i think.
once you done, you can turn on WinsCP Downloading winscp552setup.exe :: WinSCP and login in to iphone.
just enter localhost as host,, port number will be 2022
username will be root
password alpine
than press black square in vith arrow (terminal simbol) and write mount.sh and press enter, vait a few momments and close thios little window,. than go to mnt1 ar mnt2 and you have to find springboard file,,
file location is:
mnt1/System/Library/Preferences/com.apple.springboard.plist just edit this file with plist editor Download program plist Editor for Windows by VOWSoft,Ltd.
just change that digit from what you have originali, it will be about 10 if its Disabled... so just change it to something bellow 6, make it 1 or even zero. and save. than restart iphone, you will be at recovery mode, kick out from recoveriy mode with tinyumbrella and you will boot with iPhone Disabled removed...
SET IT TO ZERO or 1 witout MINUS!
The Following 2 Users Say Thank You to decco For This Useful Post:
Old 04-06-2014, 20:00   #41 (permalink)
Member: 2162843
Not working with Iphone 4 IOS 7.06. Redsnow left me with a big OK, but there was no password found even after letting it sit overnight.
The Following User Says Thank You to Trident6 For This Useful Post:
Old 04-06-2014, 20:04   #42 (permalink)
Member: 2089356
Thanks Meter: 520
Can you post a log or make photos of iphone and desktop
The Following User Says Thank You to BesfortShalaTec For This Useful Post:
Old 04-06-2014, 20:47   #43 (permalink)
Member: 2162843
BesfortShalaTec, I sent you a message.
Old 04-06-2014, 21:13   #44 (permalink)
Member: 2089356
Thanks Meter: 520
i sent it back a fix for that did you try it ?
Old 04-07-2014, 10:43   #45 (permalink)
Member: 40262
Thanks Meter: 11
Working fine I try with 7.02 Thank's Decco
Page generated in 0.22502 seconds with 8 queries
