Old 04-07-2014, 22:30   #46 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 836
i'm trying to unlock passcode on iphone 4 (3.1) ios 7.1 ..
but it doesn't work .. and according to other guides when i press launch in Gecko tool i should see AppleKeyStore:sending on my iphone screen but the only thing i see is (AppleBCMWLANCore: :handleIOKiBusyWatchingTimeout(): Error, no successful firmware download after 60000 ms!! Giving up...)
you said ignore errors and just wait .. should i ignore that error too ???
also Gecko doesn't hang or freeze (Trying all 4-digits passcodes...)
another question .. isn't the passcode stored in a .plist file i can look for and just edit it through the ssh ramdisk ??
Old 04-08-2014, 02:57   #47 (permalink)
Member: 2163643
i need video explain...
Old 04-08-2014, 13:19   #48 (permalink)
Member: 337327
Thanks Meter: 6
When I try to bruteforce the passcode on iphone 4 (3.1) ios 7.1 I get the redsn0w shows big OK but then comes with this:
Then I press launch on Gecko Tool, it freezes for 5 seconds and unfreezes without any passcode then.
Any advice?
The Following User Says Thank You to logica1 For This Useful Post:
Old 04-08-2014, 15:45   #49 (permalink)
Member: 1099349
Thanks Meter: 100
you cant view passcode in any plist file. i think your problem is that you wait too long when a Big OK on iphone screen appears,, once you see its OK on lcd, press LAUNCH in Gecko fast..
i can make a video of what im doing, but it doesnt change anything...
and this error that unsuccessful firmware download,... it should appear in between Sending rows after some minute or two after you press LAUNCH normally... we all got that error...
The Following User Says Thank You to decco For This Useful Post:
Old 04-08-2014, 16:57   #50 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 836
i'll try again and let you know if it works .. thx for the help
The Following User Says Thank You to MiRoOo For This Useful Post:
Old 04-10-2014, 11:51   #51 (permalink)
Member: 957371
Sonork: Non user
Thanks Meter: 184
Only black screen,wait about 2h nothing heppend;
Any video tutorial ? Thanks
Old 04-10-2014, 19:41   #52 (permalink)
Member: 1099349
Thanks Meter: 100
video tutorial will do nothing to be easier, just try again... and AGAIN, be sure that your iPhone 4 is 3,1 revision...
Old 04-11-2014, 01:49   #53 (permalink)
Member: 203335
Thanks Meter: 2
will this work on iphone 4 cdma if not how can i read the passlock on verizon iphone4 dont want to restore it so it dont restore to 7.1 it is on 7 want to keep that iso so i can jailbreak it please help
Old 04-11-2014, 08:25   #54 (permalink)
Cheater -Don't Deal with him-
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 511
just read the post ! makse sure JAVA JRE AND netframework 4+ is installed to w0rk this t00ls !
The Following User Says Thank You to BesfortShalaTec For This Useful Post:
Old 04-11-2014, 17:14   #55 (permalink)
Member: 2089356
Thanks Meter: 511
decco you have any ideo
Device UDID : 7e7b178fda1acfbad590d7b2b851e55bab8dbfd9
Keybag: SIGN check FAIL
Keybag UUID : 13e28245be5b4417b1395cf68ac58a73
Saving C:\Users\Besfort\Desktop\JAILBREAK\A\tools\brutefo rce\7e7b178fda1acfbad590d7b2b851e55bab8dbfd9/235f5647bb7421ea.plist
passcodeKeyboardComplexity : {'rangeMinimum': 0, 'value': 0, 'rangeMaximum': 2}
WHEN i turn on i know icloud id so can i change from icloud the password device is connented via 3G
Old 04-11-2014, 20:50   #56 (permalink)
Member: 1099349
Thanks Meter: 100
what you are talking about? i cant understand your language,,, please try to write your problem as clean as possible..
you want to change icloud password? you cant.. but you can do another trick with this if your iphone is factory unlocked and activated but passcode locked..
as i said, just try to be clear..
Old 04-11-2014, 22:21   #57 (permalink)
Member: 2089356
Thanks Meter: 511
Iphone is locked with passcode ( i cant find password with this tool cause of bug) and i am thinking to log in icloud.com with applw id ande how to change passcode (not apple id pascode) so any idea ?
Sent from my GT-I8190N using Tapatalk
Old 04-12-2014, 06:37   #58 (permalink)
Member: 1099349
Thanks Meter: 100
just try on other computer, maybe it will work.
You can try to put mobile in lost mode via icloud. then it will ask you ti add passcode, so add it.. and check how it works..
but this sounds to easy...
what is your iphone revision? and iOS ? and JAVA version ?
Old 04-13-2014, 04:42   #59 (permalink)
Member: 203335
Thanks Meter: 2
will this work with iphone4 cdma no one has ansered my question let me know if not how can i get my user lock off of my phone dont rerember screen lock code and dont want to restore phone so i dont loose my jailbreak
Old 04-13-2014, 10:09   #60 (permalink)
Member: 2089356
Thanks Meter: 511
How i know java shsh exploit wont work on cdma you will get this error
"Device unsupported"
If i helped you press thanks button ↓
Page generated in 0.36883 seconds with 7 queries
