Old 05-14-2015, 19:04   #1 (permalink)
ibhandari's Avatar
Member: 1621490
Thanks Meter: 154
iphone 4s restoring error (1) how to fix it..
iphone 4s restoring error (1) how to fix it.. any solution
Old 05-14-2015, 19:31   #2 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,250
Use search, it has been posted many times
Old 05-15-2015, 07:13   #3 (permalink)
ibhandari's Avatar
Member: 1621490
Thanks Meter: 154
but i no found any perfect solution in all theards...
Old 05-21-2015, 20:57   #4 (permalink)
Member: 2397357
hello, i hv iphone 4s n it show error " iphone is disabled" n i never sync or backup my iphone to itunes
Old 05-21-2015, 21:16   #5 (permalink)
Member: 1216144
Sonork: superack2020
tengo un iphone 4s con el mismo problema alguien a logrado
Old 05-21-2015, 21:45   #6 (permalink)
Member: 729556
This is most often a very bad error due to fault of baseband chip. Restore iPhone with iTunes on a different computer. If you get same error there is no fix. Apple handles this with replacement iPhone 4S for $199.
Here are Apple steps for error 1:
Try to restore your iOS device two more times while connected with a cable, computer, and network you know are good. Also, confirm your security software and settings are allowing communication between your device and update servers. If you still see the error message when you update or restore, contact Apple support.
Old 05-22-2015, 06:28   #7 (permalink)
ibhandari's Avatar
Member: 1621490
Thanks Meter: 154
i alredy solved this.. i changed the charging concter.. prob. solv..
Page generated in 0.18403 seconds with 9 queries
