02-18-2015, 10:25 | #1 (permalink) |
Insane Poster Join Date: Apr 2010 Location: Uk
Member: 1274866 Status: Offline Thanks Meter: 9 | Iphone 4 3.2 Disabled, cannot SHSH I have searched on here but cannot find what I am looking for, I have a disabled iphone 4 version 3.2 that I have tried to run Gecko Toolkit but I believe it wont work on 3.2. I cannot restore the phone as there is no backup, can I change this 3.2 so that Gecko will work for my device? I have also tried to SHSH but I am getting the Ignoring Unsupported error, please can someone help me out here, I am pulling my hair out thank you |
The Following User Says Thank You to leeno382 For This Useful Post: |
02-18-2015, 10:53 | #2 (permalink) | |
Moderator Join Date: Oct 2006 Location: Tunisia Age: 41
Member: 363451 Status: Offline Sonork: 100.1577895 Thanks Meter: 834 | Quote:
__________________ Regards, Mehdi | |
The Following User Says Thank You to loca|host For This Useful Post: |
02-18-2015, 11:03 | #3 (permalink) |
Member: 1274866 Status: Offline Thanks Meter: 9 | Thank you very much Localhost that seemed to of worked, will this enable me to use Gecko now or will I still have to SSH via putty or winscp to access the device? thank you once again |
02-18-2015, 11:43 | #4 (permalink) |
Member: 363451 Status: Offline Sonork: 100.1577895 Thanks Meter: 834 | Winscp --> Backup your sensitive data ( DCIM , lockdown folder .. ) --> then do whatever you want ( remove "disabled" if you have password , or make a restore if you don't )
02-18-2015, 14:22 | #6 (permalink) |
Member: 1274866 Status: Offline Thanks Meter: 9 | I have another problem, winscp worked for me but now since trying to remove the iphone disabled the phone wont boot back up its stuck on the apple logo, I basically removed the com.apple.springboard.plist then rebooted and this is what I am left with, I read on here that I should remove the file or just change the number, I opted to remove the file itself? I now cannot access Mnt1 or Mnt2 on winscp as they are both empty? |
02-19-2015, 10:49 | #7 (permalink) | |
02-19-2015, 11:17 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | As I know the second revision of iphone 4 hasn't got exploit bug, so you can do nothing with it... But I might be wrong... |
The Following User Says Thank You to ribbentrop For This Useful Post: |
02-19-2015, 11:25 | #10 (permalink) |
Member: 1274866 Status: Offline Thanks Meter: 9 | sorry I have tried to edit my post above but it wont let me. Hi upon inspection the file I have removed is from Library/LaunchDaemons/ com.apple.springboard.plist is there a way I can get a copy of this please? |
02-19-2015, 11:26 | #11 (permalink) |
Member: 1274866 Status: Offline Thanks Meter: 9 | I have now full access to the phone from Winscp and the Mnt1 and Mnt2 folder but because I have removed this file I cannot boot into the passcode screen anymore. |
02-19-2015, 12:09 | #15 (permalink) |
Member: 363451 Status: Offline Sonork: 100.1577895 Thanks Meter: 834 | Unzip this one , put it back to LaunchDaemons folder . run this 2 commands in Terminal : nvram auto-boot=1 kill 1 Post result .
