02-20-2017, 16:34 | #17 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Nord Romania Age: 42
Member: 323481 Status: Offline Thanks Meter: 43 | I know the password. The problem is the date from phone witch is in year 1970 and from here iphone is disabled over 40 years . Automatic updating the date over the sim not work, mobile data is off. I thought that is a plist file in witch is saved the date and that file can be edited to current date to fix 40 years of waiting. |
02-20-2017, 17:28 | #18 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | You have two ways to solve the problem: 1) buy/borrow/stole () OTG cable for iPhone 4, plug it into the phone and connect any USB keyboard. Then enter your code 2) By using modified Gecko tool (link on my preivious post), that tool has ability to remove disabled mode on iphone4 |
02-20-2017, 18:35 | #20 (permalink) |
Member: 323481 Status: Offline Thanks Meter: 43 | Thanks for help Ribbentrop. Have you maybe a solution for another Iphone 4 ios 7.1.1. rev 3.1, The phone have screen lock code and when i use Geko Redsn0w gets stuck on waiting for reboot on second stage. Tried on 3 PC, same problem in all. |
02-20-2017, 19:27 | #21 (permalink) |
Member: 40400 Status: Offline Thanks Meter: 1,250 | In my case it works with some conditions: - XP SP3; disabled antiviruces; just rebooted PC (do not run any other programms); untick "Automatic time zone changing" (or how it is called in English) But I've made my own unlock "box" for that |
02-21-2017, 09:16 | #22 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2665496 Status: Offline Thanks Meter: 1 | Try Bypass iCloud activation through DNS method Step 1. Tap on the Home button and then choose the "Wi-Fi Settings". From the Wi-Fi network list, tap the "i" symbol beside the Wi-Fi network which you want to connect to. Step 2. After you tap the "i", you will be led to the network settings. Remove the existing DNS, and enter the new DNS Enter the new DNS server as 78.109.17.60. Tips: According to your location, you can choose: USA/North America: 104.154.51.7 Europe: 104.155.28.90 Asia: 104.155.220.58 other areas: 78.109.17.60 Step 3. Tap on "Back" > "Done" > "Activation help." Once you accomplish the above-mentioned easy steps, a message would appear saying you have successfully connected to my server. Step 4. Tap on the "Menu" on the top right. And scroll through numbers of applications available for use such as YouTube, Mail, Maps, Games, Social, User chat, Video, Audio etc. Step 5. Select the appropriate application which you think can provide with the information you require for the owner of the phone. You also can use tools or do it online by visiting OfficialiPhoneUnlock.co.uk. More detail can be found in Bypass iCloud Activation Lock |
09-07-2018, 10:47 | #24 (permalink) |
Member: 2665496 Status: Offline Thanks Meter: 1 | If the iPhone has not been synced to computer, which means never tap on trust this computer, then there is no way to bypass the lock screen without losing data, but you can still try tricking Siri if iOS version is still under 10.3 to bypass iPhone 4 passcode. |
02-18-2020, 05:25 | #25 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2865098 Status: Offline Thanks Meter: 2 | Siri can help you bypass the iPhone passcode but its success rate is super low. Otherwise, even the most powerful TunesKit iOS System Recovery will erase the data in order to unlock the iPhone screen. |
