09-24-2012, 15:27 | #1 (permalink) |
Junior Member Join Date: Jul 2010 Location: Los angeles, CA
Member: 1353828 Status: Offline Thanks Meter: 0 | iPhone 4 problem - need help i have iphone 4 and i decided to upgrade to iOS6. i did the update via the iphone itself and i went to sleep and when i woke up the iphone was in recovery mode (cable+disk). i tried to use fix recovery from tinyumbrela and now the iphone is stuck on apple logo forever. i really need the photos from the iphone so restore is unacceptable but can anyone think of a way to the iphone up? thanks a lot, |
09-25-2012, 02:50 | #2 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Thailand
Member: 1153277 Status: Offline Thanks Meter: 8 | if u enabled icloud backup then ur photos will be in cloud or if u have backup in itunes u can restore after flash new firmware .if not then no way to get back try to restore ios6 firmware then use backup to backup ur data |
09-25-2012, 11:56 | #6 (permalink) |
Member: 1353828 Status: Offline Thanks Meter: 0 | hey, i made it! i pressed "just boot" on redsn0w 0.9.13 dev4 and the iphone came up with NO IMEI but when i connect it to ifunbox i can copy all the stuff i didn't back up. |
09-25-2012, 19:33 | #8 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1816029 Status: Offline Thanks Meter: 1 | well , look if it is now on apple logo flashing so : 1- open redsn0w (0.9.13dev4) 2- connect ur device with cable 3- select ispw from pc ( if u upgraded from idevice directly ,u have to download it to ur pc ios 6) 4- go to jailbreak from here u have to be fast 5- press on shutdown key for a long time till it will be down 6- press jailbreak ( but u have to be soooo fast before it will be back to recovery mode 7- leave it till finish note : if its not working try it again , u must be fast between u press shutdown and following the instruction for jailbreak .. |
