03-30-2016, 08:51 | #3 (permalink) |
Freak Poster Join Date: Dec 2013 Location: .................. Age: 32
Member: 2087409 Status: Offline Thanks Meter: 30 | allways use latest virsion to flash. bcoz apple server block sing of old firmware. one more way start tiny umbrela on side and update whith itune latest virsion. i hope you understand...thanks.. |
03-30-2016, 09:23 | #4 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Bulgaria
Member: 1869762 Status: Offline Thanks Meter: 52 | If case use 9.3 download new build 237 old 233 is not signed. This is solution about 3194 Sent from my iPhone using Tapatalk |
The Following User Says Thank You to aircraft For This Useful Post: |
03-30-2016, 10:41 | #5 (permalink) | ||
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Quote:
Code: Below devices support to professional flash: iPod Touch2, iPod Touch3, iPod Touch4, iPod Touch5, iPod Touch6 iPad1,iPad2,iPad3,iPad4,iPad Air,iPad Air2,iPad mini/2/3/4,iPad Pro iPhone3G,iPhone3GS,iPhone4,iPhone4s,iPhone5,iPhone5c,iPhone5s,iPhone6,iPhone6 Plus --------------------------------------------------------------------------------------------------------------------- Steps to enter DFU mode: 1. Keep device in normal mode or recovery mode, plug USB cable (please don't use USB extension cable) 2. Hold HOME button, then hold power button until screen is blank 3. Release the POWER button after about 4 seconds, but keep holding the HOME button for about 10 seconds --------------------------------------------------------------------------------------------------------------------- 14:11:26 Friendly reminder: 14:11:26 Please make sure device turned off 'Find My iPhone' 14:11:26 The device will can not activated without Apple ID after flash, in case device turned on 'Find My iPhone' 14:11:26 Method to check: Settings -> iCloud -> Find My iPhone --------------------------------------------------------------------------------------------------------------------- 14:11:26 Please connect USB cable to apple mobile device, make sure you are in DFU mode14:12:29 Retrieving information from apple mobile device14:12:29 SRTG:[iBoot-838.3] 14:12:29 Device ECID: 00000210E010834C 14:12:29 Product Type: iPhone4,1 14:12:29 Product Name: iPhone4s 14:12:29 MAIN CPU ID : 8940 14:12:29 Verifying firmware file14:12:48 MD5 value of firmware : 074670FF4FD2527678561E0BBE94A3DD 14:12:48 Filename of firmware : iPhone4,1_9.3_13E237_Restore.ipsw 14:12:48 MD5 value is different from official firmware, maybe firmware has damaged 14:12:48 Unzipping firmware file14:14:13 Apple server no longer supports the flash of this firmware version 14:14:13 Failed to flash 14:14:13 If the device doesn't exit current mode 14:14:13 Please hold the HOME and POWER buttons for about 10 seconds 14:14:13 Flash and jailbreak of apple device, please visit official website of 3uTools http://www.3u.com 14:14:13 Elapsed Time: 00:01:44 --------------------------------------------------------------------------------------------------------------------- Code: Below devices support to professional flash: iPod Touch2, iPod Touch3, iPod Touch4, iPod Touch5, iPod Touch6 iPad1,iPad2,iPad3,iPad4,iPad Air,iPad Air2,iPad mini/2/3/4,iPad Pro iPhone3G,iPhone3GS,iPhone4,iPhone4s,iPhone5,iPhone5c,iPhone5s,iPhone6,iPhone6 Plus --------------------------------------------------------------------------------------------------------------------- Steps to enter DFU mode: 1. Keep device in normal mode or recovery mode, plug USB cable (please don't use USB extension cable) 2. Hold HOME button, then hold power button until screen is blank 3. Release the POWER button after about 4 seconds, but keep holding the HOME button for about 10 seconds --------------------------------------------------------------------------------------------------------------------- 14:15:39 Friendly reminder: 14:15:39 Please make sure device turned off 'Find My iPhone' 14:15:39 The device will can not activated without Apple ID after flash, in case device turned on 'Find My iPhone' 14:15:39 Method to check: Settings -> iCloud -> Find My iPhone --------------------------------------------------------------------------------------------------------------------- 14:15:39 Please connect USB cable to apple mobile device, make sure you are in DFU mode14:16:18 Retrieving information from apple mobile device14:16:18 SRTG:[iBoot-838.3] 14:16:18 Device ECID: 00000210E010834C 14:16:18 Product Type: iPhone4,1 14:16:18 Product Name: iPhone4s 14:16:18 MAIN CPU ID : 8940 14:16:18 Verifying firmware file14:16:27 MD5 value of firmware : 885599C9C52DB8CA2BE5F5F7F59CFFDA 14:16:27 Filename of firmware : iPhone4,1_9.3_13E233_Restore.ipsw 14:16:27 MD5 value is different from official firmware, maybe firmware has damaged 14:16:27 Unzipping firmware file14:17:44 Apple server no longer supports the flash of this firmware version 14:17:44 Failed to flash 14:17:46 If the device doesn't exit current mode 14:17:46 Please hold the HOME and POWER buttons for about 10 seconds 14:17:46 Flash and jailbreak of apple device, please visit official website of 3uTools http://www.3u.com 14:17:47 Elapsed Time: 00:01:29 and itunes still is giving error 3194 same as before | ||
03-30-2016, 11:31 | #7 (permalink) |
Member: 1869762 Status: Offline Thanks Meter: 52 | iphone 4s restoring error 3194 help please No 9.2.1 use build 9.3 Or put device in dfu and get ipsw via iTunes and make new hosts Sent from my iPhone using Tapatalk |
03-30-2016, 14:15 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Fffffff!!! use 9.2.1 version for flashing and do not hesitate use search function on forum! |
The Following User Says Thank You to ribbentrop For This Useful Post: |
03-30-2016, 17:01 | #10 (permalink) | |
not what is solution for it.? search a lot on google and listen from mostly people that it is h/w. | |
03-30-2016, 18:09 | #11 (permalink) |
Member: 2087409 Status: Offline Thanks Meter: 30 | i m sorry budluck bro.. i think hardware... this codition same issue on iphone 5c 5 month past iphone is working fine but after updATE SAME ERROR AND DEVICE HANG ON LOGO AND RESTART...... |
The Following User Says Thank You to saddamh517 For This Useful Post: |
03-30-2016, 20:36 | #12 (permalink) | |
Member: 40400 Status: Offline Thanks Meter: 1,250 | Quote:
And once more, 3uTools refuses to flash new 9.3 version, I've used iTunes. | |
03-31-2016, 08:43 | #13 (permalink) | ||
thanks for inform about 3utool bro. i tried with itunes too but same. anyway....thanks to all friends for participate and help too. | ||
04-01-2016, 07:55 | #14 (permalink) | |
Freak Poster Join Date: Dec 2015 Location: HongKong
Member: 2494453 Status: Offline Thanks Meter: 200 | Quote:
So you're suggested to use Easy flash when you need to flash the firmware whose signing hasn't been stopped by Apple. If you have any questions and feedback about 3uTools, please send them to me or here https://www.facebook.com/3utool/?fref=ts. So you can get a quick solution. Thank you sir. | |
04-01-2016, 07:59 | #15 (permalink) |
Member: 2494453 Status: Offline Thanks Meter: 200 | Quote: Hi sir. The version below v1.07 can't flash new 9.3 using Pro Flash. 3uTools V1.08 can support it using Pro Flash. Did you flash new 9.3(13E237) using Easy Flash? |
