02-05-2013, 19:50 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1150882 Status: Offline Thanks Meter: 4 | iPhone 4 stuck on recovery mode after directly restoring iOS 6.1 from redsn0w MESSAGE 1: ''redsn0w can now directly restore your devise to an IPSW'' i clicked yes then 2nd message prompt MESSAGE 2: ''redsn0w will prevent BB from being updated in this restore. you,ll probably need to run 'Recovery Fix' when its complete'' And restore process begun on redsn0w itself without itunes. After restore done iphone4 has stuck into deep 'recovery mode' i tried almost every available methods like 1- redsn0w 'Recovery Fix' (doesn't work unless put the device into DFU mode) 2- RecBoot also failed it keeps rebooting again n' again into recovery mode 3- EasyBoot also failed like Recboot 4- TinyUmbrella 'Recovery Fix' can not kick out recovery mode 5- iREB6 can not fix it 6- Evasi0n can't run bcz it required a running iOS 6.1 on device to jailbreak NOW IF TRY TO RESTORE Even i have repeated the whole process twice and restore but no luck. Also tried to restore to older iOS 5.1.1 which gives me itunes errors 11,21 Found sn0wbreez updated for iOS 6.1 then i cooked custom BB preserved 6.1 firmware... which also failed on itunes error 11(which has no solution but to restore on genuine apple,s firmware) But i need to preserve BB for Gevey sim. PLEASE HELP FOR POSSIBLE SOLUTION TO JAILBREAK EITHER DOWNGRADE WITH WORKING METHOD Thnx |
02-05-2013, 20:16 | #2 (permalink) |
Freak Poster Join Date: Oct 2005 Location: pakistan Age: 40
Member: 189855 Status: Offline Thanks Meter: 31 | check which version shsh blobs u have saved, stich custom firmare and restore it,, for iso 6.1 use snowbreeze latest version 2.9.8 make custom firware and restore then jailbreak, if u have not updated bb yet mistaken with your steps u will got working cell |
02-05-2013, 20:36 | #3 (permalink) |
Member: 1150882 Status: Offline Thanks Meter: 4 | all previous 4.3.3 to 5.1.1 SHSH blobs are saved at TSS server but i dont have SHSH blobs saved on my PC. and for iOS 6.1 i used sn0wbreez 2.9.8 latest version and made a customs firmware but gettting itune restore error 11 everytime. how do i surpass this error 11? |
02-06-2013, 00:33 | #8 (permalink) |
No Life Poster Join Date: Dec 2005 Location: ((Gsm-Doctor))... Posts: 3,244 Age: 45
Member: 209093 Status: Offline Thanks Meter: 154 | after update with sn0wbreeze_iPhone_3GS-6.1-10B141 and preserve your baseband.. open redsn0w_win_0.9.15b3 .. go to extras / select IPSW / tick iPhone2,1_6.0 / finally recovery Fix... u have to continue your jailbreak as Unlock-King-PK |
02-07-2013, 19:06 | #9 (permalink) |
Junior Member Join Date: Dec 2008
Member: 919143 Status: Offline Thanks Meter: 0 | Help Please My iphone 4s jailbroken with evasion is stuk on recovery and I have tried restoring on itunes and 1000 other things, but no luck. I have an info in the phone which I need urgently. Help me please |
02-10-2013, 19:48 | #10 (permalink) | |
Member: 1150882 Status: Offline Thanks Meter: 4 | Quote:
Solution1: just use 'Recovery fix' method from latest redsn0w... and before that use iREB to put your device in DFU mode Solution2: step1 must use iREB After putting in DFU mode, step2 tethered jailbreak your device again with latest redsn0w.. go to extras > select IPSW > choose official iOS6.0 IPSW file > then go back and run jailbreak. NOW the important part is while jailbreaking when it REBOOT the devise and your iphone screen turn on without* apple logo then YOU ARE SUCCESSFULLY OUT OF RECOVERY MODE... and jailbreak procedure follows till end. hope this can help | |
02-11-2013, 02:48 | #12 (permalink) | |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | Quote:
Recovery fix is supported only A4 device (like 3GS, 4G) and for delavand when restore your device has it error code num what? at the end, if your device have error code 1 or -1 may be it has problem beseband IC that make your 4s stuck in recovery mode. the only way to solve that teke it to customer care regard kjava | |
02-11-2013, 08:28 | #13 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1882296 Status: Offline Sonork: barucho Thanks Meter: 0 | good day to all of you... im a newbie here. i dont know kung tama ba na dito ko i post ang query ko. just help me nalang... my unit is iphone4 nag upgrade po ako ng version 6.0.1 then ngayun po pag may sinasagot akong tawag hindi ko po marinig yun kabilang line and after 15-20 secs nag e end call na sya. it is possible na hindi compatible ang iphone4 sa version 6.0.1? thanks po... |
02-13-2013, 21:03 | #14 (permalink) |
Member: 1883622 Status: Offline Thanks Meter: 0 | Hi Ive just come across this question while tearing my hair out trying to find a solution to a question very similar to this one I have an iphone 4g. It was bought to do up from ebay and is stuck in recovery mode (broken screen also amongst other things) The error code quoted was 3194. So someone trying to restore to unsigned ios. I connected it up to redsnow (latest version) and restored to iOS 6.1 using restore to an IPSW feature. This was successful. Brilliant i thought. When i tried to use recovery fix as directed it gave lots of errors and didnt work. Racking my brains (and Google's) I have realised that it is iOS 6.1 and the recovery fix only works up to 6.0.1 (using 6.0 to boot out of recovery) I tried then restoring in itunes this time which threw up error 40. I put phone into DFU mode and the restore was succesful. Brilliant again i thought! That must have done the trick......the iphone rebooted into recovery mode again! So does anyone have any solutions, ideas, tips for how to get this iphone 4 out of recovery mode! Im guessing i need redsnow to be working with 6.1 to kick out of recovery but not happening at moment I have no blobs for this phone. I even tried to restore it to 4.1 but error 3194 occurred, im guessing thats cos its a 4 not a 3GS and itunes not signing it anymore I would be really grateful for any help you can give and now ive found this site im quite happy to give out any help in the future Thanks in advance |
02-13-2013, 21:48 | #15 (permalink) | |
2nd u must use iREB After putting in DFU mode 3rd tethered jailbreak your device with latest redsn0w.. go to extras > select IPSW > choose official iOS6.0 IPSW file > then go back and run jailbreak. NOW the important part is while jailbreaking when it REBOOT the devise and your iphone screen turn on *WITHOUT* apple logo then YOU ARE SUCCESSFULLY OUT OF RECOVERY MODE... and jailbreak procedure follows till end. after jail breaking install evasi0n from cydia for untethered JB hope this can help | |
