04-17-2017, 08:42 | #1 (permalink) |
Freak Poster Join Date: Nov 2016 Location: Hong Kong Age: 31
Member: 2652321 Status: Offline Thanks Meter: 34 | How to Solve All Sources in Cydia Are Empty After jailbreak? Step 1: Download and install the latest 3uTools on your PC. Step 2: Run 3uTools, connect iPhone to PC using the USB cable. Click Toolbox -> Open SSH. After opeing the SSH channel, please keep the IP, Port, Default ID(Root) and Password in mind. Step 3: Download Winscp.exe. Step 4: Run Winscp.exe -> enter the IP, Port, Default ID(Root), Password(alpine) -> click Save. Step 5: After finish filling the blanks above, click Confirm, and then you can log into Winscp. Step 6: An alarm may appear on your computer, please click Yes. Step 7: And then you’ve connected your iDveice to the computer successfully. At this time, you need to download a compressed file “var.lib.apt.tar” on your computer. Step 8: Please drag the file “var.lib.apt.tar” into jailbreak files directly. Step 9: Right click the compressed file “var.lib.apt.tar” ->select “File Custom Commands” ->click “enter ...”. Step 10: Enter “tar-xpvf!-c/” in custom command -> select the option “Display the results in the terminal” -> click Confirm-> continue to click “Confirm”. A console window should be displayed on your computer, just click “Close”. All the operations are done till now. Restart Cydia and then Cydia can work normally. |
04-17-2017, 08:44 | #2 (permalink) |
Member: 2652321 Status: Offline Thanks Meter: 34 | 3uTools is a free & safe iOS tool, download link: 3uTools | iOS jailbreak & flash tool If you have any problem or suggeston about 3uTools, please post them on https://www.facebook.com/groups/3uTools/, and then you'll get a fast reply. |
