10-23-2012, 02:25 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: From Uzbekistan
Member: 545722 Status: Offline Sonork: 100.1619680 Thanks Meter: 322 | iphone 4g ios6 TinyUmbrella cannot save shsh help need downgrade Iphone 4g iOS6 TO 5.1.1 10/23/2012 06:18:39.343 Caching shsh files... 10/23/2012 06:18:39.359 Found [1] shsh files to cache... 10/23/2012 06:18:39.359 Cached [1] shsh files 10/23/2012 06:18:39.359 Device connected: iPhone Smartsmen 10/23/2012 06:18:39.359 You are using the current version of TinyUmbrella. 10/23/2012 06:18:39.375 Loaded History... 10/23/2012 06:18:39.484 Loaded History... 10/23/2012 06:22:03.281 Started saving SHSHs for [iPhone Smartsmen] 10/23/2012 06:22:03.296 iPhone4 6.0gm (10A403)-885049451342 already exists! Skipping... 10/23/2012 06:22:23.015 For version [iPhone4 4.3 (8F190)] - This device isn't eligible for the requested build. 10/23/2012 06:22:23.015 APPLE is NOT signing iPhone4 4.3 (8F190) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:23.062 For version [iPhone4 4.1 (8B117)] - This device isn't eligible for the requested build. 10/23/2012 06:22:23.062 APPLE is NOT signing iPhone4 4.1 (8B117) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:23.734 For version [iPhone4 4.2.1 (8C148)] - This device isn't eligible for the requested build. 10/23/2012 06:22:23.750 APPLE is NOT signing iPhone4 4.2.1 (8C148) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:23.828 For version [iPhone4 4.0.2 (8A400)] - This device isn't eligible for the requested build. 10/23/2012 06:22:23.843 APPLE is NOT signing iPhone4 4.0.2 (8A400) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:24.625 For version [iPhone4 4.0.1 (8A306)] - This device isn't eligible for the requested build. 10/23/2012 06:22:24.640 APPLE is NOT signing iPhone4 4.0.1 (8A306) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:24.656 For version [iPhone4 6.0b3 (10A5355d)] - This device isn't eligible for the requested build. 10/23/2012 06:22:24.671 APPLE is NOT signing iPhone4 6.0b3 (10A5355d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:25.359 For version [iPhone4 4.2b3 (8C5115c)] - This device isn't eligible for the requested build. 10/23/2012 06:22:25.359 APPLE is NOT signing iPhone4 4.2b3 (8C5115c) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:25.453 For version [iPhone4 4.3b2 (8F5153d)] - This device isn't eligible for the requested build. 10/23/2012 06:22:25.468 APPLE is NOT signing iPhone4 4.3b2 (8F5153d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:26.187 For version [iPhone4 4.3b3 (8F5166b)] - This device isn't eligible for the requested build. 10/23/2012 06:22:26.203 APPLE is NOT signing iPhone4 4.3b3 (8F5166b) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:26.234 For version [iPhone4 4.3b1 (8F5148b)] - This device isn't eligible for the requested build. 10/23/2012 06:22:26.234 APPLE is NOT signing iPhone4 4.3b1 (8F5148b) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:26.656 For version [iPhone4 4.3.2 (8H7)] - This device isn't eligible for the requested build. 10/23/2012 06:22:26.656 APPLE is NOT signing iPhone4 4.3.2 (8H7) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:27.187 For version [iPhone4 4.3.3 (8J2)] - This device isn't eligible for the requested build. 10/23/2012 06:22:27.203 APPLE is NOT signing iPhone4 4.3.3 (8J2) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:27.421 For version [iPhone4 4.3.5 (8L1)] - This device isn't eligible for the requested build. 10/23/2012 06:22:27.437 APPLE is NOT signing iPhone4 4.3.5 (8L1) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:27.921 For version [iPhone4 4.3.4 (8K2)] - This device isn't eligible for the requested build. 10/23/2012 06:22:27.937 APPLE is NOT signing iPhone4 4.3.4 (8K2) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:28.171 For version [iPhone4 4.3.1 (8G4)] - This device isn't eligible for the requested build. 10/23/2012 06:22:28.171 APPLE is NOT signing iPhone4 4.3.1 (8G4) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:28.671 For version [iPhone4 5.1b1 (9B5117b)] - This device isn't eligible for the requested build. 10/23/2012 06:22:28.671 APPLE is NOT signing iPhone4 5.1b1 (9B5117b) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:29.156 For version [iPhone4 4.0 (8A293)] - This device isn't eligible for the requested build. 10/23/2012 06:22:29.156 APPLE is NOT signing iPhone4 4.0 (8A293) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:29.500 For version [iPhone4 5.0.1 (9A405)] - This device isn't eligible for the requested build. 10/23/2012 06:22:29.515 APPLE is NOT signing iPhone4 5.0.1 (9A405) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:29.984 For version [iPhone4 5.0b7 (9A5313e)] - This device isn't eligible for the requested build. 10/23/2012 06:22:29.984 APPLE is NOT signing iPhone4 5.0b7 (9A5313e) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:30.359 For version [iPhone4 5.0b1 (9A5220p)] - This device isn't eligible for the requested build. 10/23/2012 06:22:30.359 APPLE is NOT signing iPhone4 5.0b1 (9A5220p) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:30.828 For version [iPhone4 5.0b6 (9A5302b)] - This device isn't eligible for the requested build. 10/23/2012 06:22:30.828 APPLE is NOT signing iPhone4 5.0b6 (9A5302b) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:31.140 For version [iPhone4 5.1b2 (9B5127c)] - This device isn't eligible for the requested build. 10/23/2012 06:22:31.140 APPLE is NOT signing iPhone4 5.1b2 (9B5127c) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:31.625 For version [iPhone4 5.0b2 (9A5248d)] - This device isn't eligible for the requested build. 10/23/2012 06:22:31.640 APPLE is NOT signing iPhone4 5.0b2 (9A5248d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:32.000 For version [iPhone4 5.0b3 (9A5259f)] - This device isn't eligible for the requested build. 10/23/2012 06:22:32.000 APPLE is NOT signing iPhone4 5.0b3 (9A5259f) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:32.484 For version [iPhone4 5.0b4 (9A5274d)] - This device isn't eligible for the requested build. 10/23/2012 06:22:32.484 APPLE is NOT signing iPhone4 5.0b4 (9A5274d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:32.828 For version [iPhone4 5.0b5 (9A5288d)] - This device isn't eligible for the requested build. 10/23/2012 06:22:32.843 APPLE is NOT signing iPhone4 5.0b5 (9A5288d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:33.281 For version [iPhone4 6.0b4 (10A5376e)] - This device isn't eligible for the requested build. 10/23/2012 06:22:33.296 APPLE is NOT signing iPhone4 6.0b4 (10A5376e) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:33.750 For version [iPhone4 5.0 (9A334)] - This device isn't eligible for the requested build. 10/23/2012 06:22:33.765 APPLE is NOT signing iPhone4 5.0 (9A334) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:34.093 For version [iPhone4 5.1b3 (9B5141a)] - This device isn't eligible for the requested build. 10/23/2012 06:22:34.109 APPLE is NOT signing iPhone4 5.1b3 (9B5141a) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:34.578 For version [iPhone4 5.1 (9B176)] - This device isn't eligible for the requested build. 10/23/2012 06:22:34.593 APPLE is NOT signing iPhone4 5.1 (9B176) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:34.968 For version [iPhone4 5.1.1 (9B206)] - This device isn't eligible for the requested build. 10/23/2012 06:22:34.968 APPLE is NOT signing iPhone4 5.1.1 (9B206) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:35.281 For version [iPhone4 5.1.1b (9B208)] - This device isn't eligible for the requested build. 10/23/2012 06:22:35.296 APPLE is NOT signing iPhone4 5.1.1b (9B208) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:35.750 For version [iPhone4 6.0b1 (10A5316k)] - This device isn't eligible for the requested build. 10/23/2012 06:22:35.765 APPLE is NOT signing iPhone4 6.0b1 (10A5316k) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:36.140 For version [iPhone4 6.0b2 (10A5338d)] - This device isn't eligible for the requested build. 10/23/2012 06:22:36.140 APPLE is NOT signing iPhone4 6.0b2 (10A5338d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do. 10/23/2012 06:22:36.156 Finished saving SHSHs for [iPhone Smartsmen] 10/23/2012 06:22:36.625 Caching shsh files... 10/23/2012 06:22:36.640 Found [1] shsh files to cache... 10/23/2012 06:22:36.750 Cached [1] shsh files |
